Hello everyone,
I'm building the circuit here: http://www.electronicsforu.com/efylinux/circuit/may2003/ci4-clap.pdf
I started building it without the mic and simulated a mic with a piece of wire (short circuit vs open circuit) - everything seems to work after a fix up of the Decade counter circuit.
I then bought several condenser mics and tried it with them, but I can't get a response if I clap (or any sort of response).
Currently this is one of the mics I have: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=102-1732-ND
The voltage drop across it is about 8V.
Does anyone have any suggestions as to what I should try? Another mic? Thanks in advance!
