All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-25-2010, 10:38 PM
Lee_831 Lee_831 is offline
Default Low-Side Current Sensing for MPPT
Hi Guys,
I'm new to this forum but it has already been a great help!
My name is Lee and I'm doing an MSC project in MPPT technologies. I'm looking for some help with the design..
Apologies if this material has been covered before!
I have coded what I believe to be a Perturb and Observe algorithm in C, to be run on a PIC16F877A Micro-controller, which I intend to hook up to a DC Buck Converter.
My last concern is with measuring the current flow in the circuit, it has been suggested that I use a low-side current sensing op-amp. I'm not a particularly analogue-minded person, and could do with some help!
I'm looking to have a shunt resistor of around the order 10 Ohms, and use a 741 as the op-amp, and I'm feeding the op-amp output into a PIC16F877A's ADC input, which has a reference voltage of 5v.
At maximum sunlight, the cell produces about 1.5mA at 5v, and at this level I'd like the output of the 741 to be at the 5v maximum. Does this sound feasible? There seems very little in the way of tutorials on how to design these circuits.
I very much appreciate your help,
Lee
  #2
Old 08-25-2010, 10:57 PM
tom66 tom66 is offline
Default
I'm not sure about your main question, but be aware that your LM741 won't be able to put out +5V with a +5V input. It also cannot go to ground.
  #3
Old 08-25-2010, 11:03 PM
Default
Thanks for your quick reply,
My main question is how do I design a low-side current sensor circuit, ie what are the values of resistor / capacitor that I should use on the inputs and as the feedback resistance?
Would you recommend an alternative op-amp for this application?
Thanks,
Lee
  #4
Old 08-25-2010, 11:06 PM
Default
Well, if you need to go to zero and you can afford to power the op-amp from about +8V, an LM358 will do the job fine. But if you need a rail-to-rail op-amp, that can go up to +5V with a +5V input, the choices are many and I'm not certain of an industry standard part.
  #5
Old 08-25-2010, 11:08 PM
retched's Avatar
retched retched is offline
Default
Here is some MPPT info:
Read these:
http://circuits.linear.com/339
http://www.ti.com/litv/pdf/slva378
Also, attached is a PDF with some good info on the perturb and observe method. Check out the circuit to see how they do it.
Also attached is a app note that may help.
__________________
-rm-
  #6
Old 08-26-2010, 01:09 AM
sage.radachowsky sage.radachowsky is offline
Default
Here's an idea. This is a simple non-inverting amplifier. The current over the sense resistor is ramped up and the output of the amplifier multiplies it by 250 times.
However, the devil is in the details. Getting an actual op amp to work this well may be tricky. This model is an idealized op amp.
You'll need either (A) true rail-to-rail input or (B) a negative power rail for the op amp.
You'll also need to use an op amp with a very low offset error, or trim one if it has the nulling inputs. Otherwise your very low voltages over the 10 Ohm resistor will be overshadowed by the offset error.
Tags
Related Site Pages
Section Title
Worksheet Negative feedback opamp circuits
Worksheet Basic operational amplifiers
Textbook Practical considerations : Operational Amplifiers
Video Lecture Op Amps Characteristics (Part 2) - Internal Circuitry - Op Amps and Op Amp Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Low side current sensing DumbDummy77 General Electronics Chat 15 04-01-2010 02:28 AM
mosfet current sensing circuit. savage67 General Electronics Chat 2 01-19-2010 06:07 PM
High voltage extremely low currents Ynot1980 Off-Topic 1 12-16-2009 11:32 PM
LEDs, 555s, Flashers, and Light Chasers (Test) Bill_Marsden General Electronics Chat 13 02-06-2009 07:03 PM
high sensitivity current sensing fridgedr General Electronics Chat 13 11-18-2008 03:48 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
