Hello all,
I have a circuit that I have ripped out of an Oust fan, which runs off a 1.5v D-cell battery and is designed to run a 1.5v dc motor (which, of course, constitutes the fan). Photos of these parts are below as attachments (sorry, no schematics...).
My questions to you all are: in place of the 1.5v dc motor fan, can I attach a 3.3v or 5v dc fan without risking the circuit? Would the fan even run? Or run, but slower (which is OK)? Or can I use a 3.3v or 5v dc fan and attach a 3v battery instead? With either of these alterations how would battery life be affected? Would I then be better going for 3v lithium battery, instead of 1.5v or 3v alkaline, to compensate or is this irrelevant? Would I blow the circuit?
The 3.3v and 5v fans I had in mind are the following:
http://au.mouser.com/ProductDetail/ebm-papst/605F/?qs=sGAEpiMZZMvuXzJ9NcThavzCYjsQ%2bSmiQSD5E/ZtD4I=
http://www.alliedelec.com/fans-motors-thermal-management/fans/?N=4294789992+4294838606
Basically I want to use a 3.3v or 5v dc fan because they have a much slimmer profile than any fan I've seen that runs off a 1.5v dc motor. I want to use the Oust fan circuit since it regulates the fan to switch on for 5 minutes every 15 minutes, which is perfect for my application. This setup is to be assembled in as small a box as possible to circulate the air and humidity within my humidor. I'd even use a 9v fan if that was a realistic option, but I don't know how battery life would go then. The fan doesn't need to go fast at all, it just needs to circulate the air in the space about the size of a large shoe box.
Your help is very much appreciated in advance, I'm ashamed I don't know these answers myself, and considerable scouring through various internet sites hasn't turned up an answer for me either! I'd love direct answers to this barrage of questions, or direction to a resource where I could work it out.
Cheers,
Paul.
Cheers,
Paul.
