All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-19-2010, 08:14 PM
jeay pakistan jeay pakistan is offline
Red face thyristor firing angle control using microcontroller
hy huys .i m working on project "slip power recovery drive for 3p slip ring induction motor" and want to design inverter using scr can any budy guide ma to adjust firing angle using microcontroller
  #2
Old 08-19-2010, 08:33 PM
beenthere's Avatar
beenthere beenthere is offline
Default
You will need an input from a zero crossing detector to synch the microprocessor with the AC line. The phase angle may be adjusted by triggering the SCR at any desired time after the AC waveform crosses zero. The period is 20 milliseconds for 50 Hz power.
__________________
First comes the hardware, then the software.
  #3
Old 10-09-2010, 03:49 PM
cpleng7 cpleng7 is offline
Default
can explain more detail in the zero crosing detector
  #4
Old 10-10-2010, 07:47 AM
DickCappels DickCappels is offline
Default
Here is the basic idea. If you use an appropriately rated opto-isolator, you can have your firing circuit operate near ground, isolated from the power line -much safer, particularly early in the game, when you might want to monitor waveforms. You can drive your thysistor's gate through an isolated pulse transformer. If you do this, make sure your control circuit is properly grounded for your own safety (and keep one hand in your back pocket!)
Tags
Related Site Pages
Section Title
Worksheet Thyristors
Worksheet Thyristor application circuits
Textbook Selsyn (synchro) motors : Ac Motors
Textbook Tesla polyphase induction motors : Ac Motors
Textbook The TRIAC : Thyristors
Textbook Field-effect-controlled thyristors : Thyristors
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook The DIAC : Thyristors
Textbook The Shockley Diode : Thyristors
Textbook Hysteresis : Thyristors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Multiple LED control with microcontroller DancinNancy Embedded Systems and Microcontrollers 5 07-28-2012 02:55 AM
control an ip camera over wifi with microcontroller??? thanosgen Embedded Systems and Microcontrollers 1 03-19-2010 03:14 PM
What is the best microcontroller to control a line following robot? icem The Projects Forum 7 01-04-2010 01:33 AM
Need help for a dawn/dusk LED circuit malaybiswas The Projects Forum 24 03-04-2009 04:19 PM
Difference between Controller, Microcontroller & Microprocessor in control system Sub System Computing and Networks 4 11-03-2008 03:40 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
