I have an audio project that I'm working on. My guitar pickup outputs a sine wave anywhere from .05 to 1 V Peak to Peak, from 200Hz to 20Khz (haven't found the actual upper limit, using theoretical limits). I want to convert this to a square wave, retaining both the frequency and voltage of the original signal.
I've found zero crossing detectors that solve the frequency problem, however they output at only the voltage given to the comparator. There were a few 'self powered' sine to square converters, but they required a minimum of .75mV.
Does anyone have any ideas? Ideally it would be a chip powered by 3 AA batteries, or even self-powered with a voltage multiplier.
