I am interested in understanding more about the theory & operation of PSC motors (like those used for HVAC condenser fans & compressors). I think I understand that the purpose of the "run" capacitor is to create a phase shift in the current to the stator's aux or "start" windings, in order to produce a rotating magnetic field / net torque to start the rotor.
My question relates to the design considerations in sizing the run capacitor.
Since I haven't been able to find any "typical" values for the inductance of the start & run windings, I am unable to analytically characterize the typical circuit.
But, qualitatively, if the start winding current needs to be phase shifted 90 degrees relative to the run winding current (for a motor with start & run poles 90 degrees apart), it seems to me that this means that the value of the run capacitor needs to be selected such that the overall impedance of the series circuit (start winding in series with run capacitor) is totally resistive (or even slightly capacitive to compensate for the series resistance of the run winding) at 60 Hz.
That way, the current in the run winding lags the supply voltage by just short of 90 degrees, and the current in the start winding is approximately in-phase with the supply voltage, giving a 90 degree difference in the currents in run & start windings.
Can anyone confirm this or give me a different way to look at it? (I have some follow up questions once I get this resolved)
Thanks!
Thanks!
