All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-14-2010, 02:57 AM
edvard_m edvard_m is offline
Question Diode as voltage regulator problem
Hi everyone. I'm trying to build a cheap voltage regulator to have a regulated voltage of 1.4V from a 3V source. I was trying to do something similar to what was presented here: http://www.reuk.co.uk/Zener-Diode-Voltage-Regulator.htm but I couldn't find a zener diode on Digikey with a Zener voltage of 1.4V (or .7V to put in series).
Now I'm just looking for any through hole axial diode to get a 1.4 drop across. The problem is on Digikey, the parts say Forward Voltage .7V @ 1A or .7V @ 5A etc. I know I want .7V Forward Voltage, but how do I know what current will be going through the diodes?
Thanks.
  #2
Old 08-14-2010, 03:00 AM
marshallf3's Avatar
marshallf3 marshallf3 is offline
Location: Oklahoma City, OK. Large enough to be modern but plenty of country left around it.
Default
Just ignore the current rating, virtually all regular silicon (but not schottky) rectifiers will drop between 0.6 - 0.7V across the junction if the current is kept within it's its operating range.
__________________
The very first course in engineering school should be how to use Google and Wikipedia
I very often misspell or miss things while making posts so come back and double check a few times.
I also have a full time job and often 10 projects going on at the same time so I'm not always online.
  #3
Old 08-14-2010, 03:03 AM
Ghar Ghar is offline
Default
Check out the diode datasheet to see a plot of voltage vs current.
You'll see there's quite a bit of variation even in the same part number (with temperature, current, whatever)
You set the current using a resistor, usually called the 'current limiting resistor'. There are a lot of calculators and explanations online on how to do this.
  #4
Old 08-14-2010, 03:12 AM
Default
Ok. I know my load draws about 1mA. How do i know if the current will be within its operating range if I don't know what the current running through the diodes is? If it is too low, then won't i get a smaller voltage drop across each diode based on the i-v characteristics of a diode?
  #5
Old 08-14-2010, 03:21 AM
Default
The current in the diode will be:
(Vsource - Vdiode)/R - ILoad
Vdiode won't be changing that much for small changes in current but you can follow the graph to see where you are.
The change is something like 0.1 V for every decade of current (factor of 10), it depends on the exact diode.
  #6
Old 08-14-2010, 04:11 AM
marshallf3's Avatar
Default
Unless you're shooting for absolute precision I consider it to be a non-issue in most simple circuitry.
__________________
  #7
Old 08-14-2010, 07:07 AM
Default
Ok. If I chose a 0.7V Forward Voltage (FV) @ 1A, if I ran it at .1A, I'd already be down to about 0.4V FV.
So I found another diode that operated at 1.7V FV @ 1A. I looked at the i-v curve and it looks like if the diode current is 10mA, I can get the FV to be 0.7V.
http://www.diodes.com/datasheets/ds25002.pdf The UF1005
I1 = Idiode + Iload
(3V-1.4V)/R1 = 10mA + 1mA = 11mA
This means I need R1 to be 14.5Ω. Is this calculation correct? I want to run as little current as possible through the diodes to save the 2AA batteries, but it looks like this is the least current I can supply from what I have to choose from on Digikey.
  #8
Old 08-14-2010, 04:05 PM
Default
You're off by a factor of 10, it's 145 ohms.
You should plug the value back in to check especially when it's such a short equation.
How close do you need to be though? You could cut power consumption in half and lose less than 0.1V.
The diodes themselves will be off from the datasheet number as well, so you'll probably need to adjust it if you want exactly 1.4V
It'll also change with your load unless it's a constant 1 mA.
Marshallf does have a good point.
You could also look into putting 3 Schottkys in series, you might be able to find ones that work with 1.4V at a lower current.
  #9
Old 08-15-2010, 01:00 AM
Audioguru Audioguru is offline
Banned
Default
A diode is not a voltage regulator.
The voltage across a diode changes when its current and temperature changes.
You should use a low current voltage reference IC.
  #10
Old 08-16-2010, 12:38 PM
sage.radachowsky sage.radachowsky is offline
Default
Yes, here is a 1.5V reference.
Tags
Related Site Pages
Section Title
Textbook Zener diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Working Of 7805 Linear Regulator IC shankey_1919 General Electronics Chat 4 02-19-2010 11:33 AM
Voltage Divider with a Transistor Help rachshot65 General Electronics Chat 8 02-03-2010 06:06 PM
Diode Voltage in Temperature matan Homework Help 1 05-21-2009 03:44 PM
what device can i use other than zener diode as an constant voltage source premkumar General Electronics Chat 8 07-03-2007 11:30 AM
fields alphaone Physics 4 12-23-2005 06:03 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
