PIC Sound Generator
ELECTRONERD
Joined May 26, 2009
1,147
Hey Everyone,
I haven't been on AAC for a little while, my job has kept me busy. I still browse the other posts when I can, and I try to remain assiduous at my projects after I finish work each day, if time permits of course. :)
Project:
I just began programming with PICs and have run through a series of projects to exercise my skill level in programming; this particular project is entitled a "PIC Sound Generator" in which it will generate notes at my command.
Theory & Operation:
I begin with all my header files, definings, etc. until I reach my first function. This function allows me to enter a note that I previously stored into an array, and then define how long of a duration I wish it to play for.
My frequency is set by Timer0 on the PIC, in which I rapidly turn RA0 on and off depending on my TMR0L and TMR0H values, and furthermore, my array value. TMR0H and TMR0L enable me to use 16-bit mode since my lowest note is 1515μS. Remember that I wish to know my lowest frequency note since the delay is longer. If I were to use 8-bit, my maximum delay would be 128μS. Thus, equation for 16-Bit timer:
\(Frequency Delay = [(65536 - Delay)*0.5uS]2\)
Which simplifies to:
\(Frequency Delay (uS) = (65536 - Delay)\)
It has already been noted to me that Timer2 would be a better choice, but I wish to become more familliar with all the PICs abilities and attributes, so I will eventually learn about Timer2 as well.
In the main() function, you see I have a long list of the playNote function commands. These, as I mentioned, give me what note I want and for how long I wish to play it. The latter statement is based on whole notes (actually quarter notes) and half notes (actually eighth notes). The music is depicted here:
http://upload.wikimedia.org/wikipedia/commons/4/49/Gstk.png
The time signature is 3/4; meaning there are 3 quarter (1/4) notes per measure; or section in my comments. Therefore, to make the music even, a section must eventually add up to 3 quarter notes. Otherwise, the music becomes convoluted and not very pleasant to listen to. I can, at my disposal, change how fast I want my music to play if I change my WHOLE or HALF values previously defined at the beginning. Note that they correlate with one another; if I have 800 as the WHOLE, I must have half of that for the HALF value. I was fortunate to have experience in this regard (I play classical guitar), so that made things much easier.
Code:
  • Using PIC18F1320, with C18 compiler
Rich (BB code):
// CreatingSound2.C Song "God Save The Queen"
 #include <p18f1320.h>
 #include <delays.h>
 #include <stdlib.h>
 #pragma config OSC=INTIO2, WDT=OFF, LVP=OFF, DEBUG=ON
 #define PAUSE Delay1KTCYx(50);
 #define WHOLE 1000
 #define HALF 500
 #define LONG 2000
void playNote(unsigned int note, unsigned int timer)   // Note & Timer driver; determines which note will be played and for how long
    unsigned int times, freq, notes[] = {64021, 64105, 64185, 64260, 64331, 64398, 64462, 64522, 64578, 64632, 64682, 64730, 64774, 64817, 64856, 64895};
                freq = notes[note];   // Determine frequency based on array value
                INTCONbits.TMR0IF = 0;   // Clear OVF Flag
                LATA = 0x01;   // Initialize LATA
                TMR0L = freq & 0xFF;
                TMR0H = (freq >> 8) & 0xFF;
                T0CON|=0x80;
                for(times=timer;times>0;times--)   // Duration of playing
                                TMR0H = (freq >> 8) & 0xFF;   //Load TMR0H byte first
                                TMR0L = freq & 0xFF;   // Load TMR0L byte next
                                while(!INTCONbits.TMR0IF);   // Wait for timer
`        INTCONbits.TMR0IF = 0;   // Clear OVF Flag
        LATA = ~LATA;   // Invert output
   PAUSE;
 void main()
 OSCCONbits.IRCF0=1;
 OSCCONbits.IRCF1=1;
 OSCCONbits.IRCF2=1;
 T0CONbits.TMR0ON = 0;   // Don't turn timer on yet
 T0CONbits.T08BIT = 0;  // Timer0 is configured as 16-bit timer
 T0CONbits.T0CS = 0;   // Use internal clock
 T0CONbits.PSA = 1;   // Prescaler is not assigned
 T0CONbits.T0PS2 = 0;
 T0CONbits.T0PS1 = 0;
 T0CONbits.T0PS0 = 0;
 while(!OSCCONbits.IOFS);
 TRISA = 0b11111110;   // Use RA0 as output
 while(1)
  playNote(3, WHOLE);  // Section 1
  playNote(3, WHOLE);
  playNote(3, WHOLE);
  playNote(1, WHOLE);  // Section 2
  playNote(3, HALF);
  playNote(5, WHOLE);
  playNote(7, WHOLE);  // Section 3
  playNote(7, WHOLE);
  playNote(8, WHOLE);
  playNote(5, WHOLE);  // Section 4
  playNote(7, HALF);
  playNote(8, WHOLE);
  playNote(12, WHOLE); // Section 5
  playNote(0, WHOLE);
  playNote(7, WHOLE);  // Section 6
  playNote(8, HALF);
  playNote(10, WHOLE);
  playNote(12, WHOLE); // Section 7
  playNote(13, WHOLE);
  playNote(10, WHOLE); // Section 8
  playNote(10, HALF);
  playNote(5, WHOLE);  // Section 9
  playNote(1, WHOLE);
  playNote(3, HALF);
  playNote(3, LONG);  // Section 10
  playNote(10, WHOLE); // Section 11
  playNote(10, WHOLE); // Section 12
  playNote(8, HALF);
  playNote(7, WHOLE);
  playNote(8, WHOLE);  // Section 13
  playNote(8, WHOLE);
  playNote(8, WHOLE);
  playNote(8, WHOLE);  // Section 14
  playNote(7, HALF);
  playNote(5, WHOLE);
  playNote(5, WHOLE);  // Section 15
  playNote(7, WHOLE);
  playNote(7, HALF);
  playNote(0, LONG);  // Section 16
  playNote(15, WHOLE); // Section 17
  playNote(15, WHOLE); // Section 18
  playNote(13, HALF);
  playNote(13, WHOLE); // Section 19
  playNote(13, WHOLE); // Section 20
  playNote(12, HALF);
  playNote(7, WHOLE);  // Section 21
  playNote(8, HALF);
  playNote(7, HALF);
  playNote(5, HALF);
  playNote(3, HALF);
  playNote(7, WHOLE);  // Section 22
  playNote(8, HALF);
  playNote(12, WHOLE); // Section 23
  playNote(5, WHOLE);
  playNote(3, HALF);
  playNote(3, LONG);  // Section 24
  playNote(12, WHOLE); // Section 25
  playNote(13, HALF);
  playNote(12, HALF);
  playNote(10, HALF);
  playNote(8, HALF);
  playNote(7, WHOLE);  // Section 26
  playNote(5, HALF);
  playNote(3, WHOLE);
  playNote(5, WHOLE);  // Section 27
  playNote(7, WHOLE);
  playNote(7, HALF);
  playNote(0, LONG);  // Section 28
  Delay100TCYx(255);
A picture of my setup is depicted in the attachements and to see it working click the following link:
http://s974.photobucket.com/albums/ae227/ElectroNerdy/uC%20Video/?action=view&current=PICSoudGenerator.mp4&newest=1
On the o'scope you'll notice that the waveform is somewhat distorted, this is due to the speaker. If I were to take that off, not only would you not have any sound (obviously), but it would then give you an adequate square wave.
I hope you all enjoyed this! If you have any suggestions or comments for me, please feel free to mention them! I would be grateful for any comments in order to edify myself.
I would like to thank 3v0 and Hayato for their help!
Austin
retched
Joined Dec 5, 2009
5,207
The ability to read an external file, possibly from a memory card, to enable you to compose separate 'songs' without needing separate PICs to play them would be a nice next logical step.
This is a nice project for folks who wish to get involved in PIC programming and in-circuit programming.
It gives instant feedback of a job-well-done.
Good Job.
ELECTRONERD
Joined May 26, 2009
1,147
Thanks Retched!
Now I'm storing additional songs into 2D arrays, containing the notes and time values. I plan on having three switches which will enable me to select between the three different songs. I'll post the results here when I finish!
bertus
Joined Apr 5, 2008
23,006
When you made the changes, can you also post the schematic?
Then it would be a complete project.
Bertus
ELECTRONERD
Joined May 26, 2009
1,147
Hi Bertus,
It really isn't much of a schematic, simply a 47μF cap connected from the RA0 I/O pin and then to the speaker.
If you think it is necessary, I can make a schematic.
retched
Joined Dec 5, 2009
5,207
Might as well post the schematic. Im sure this will be a popular project with first time uC users. At least that way they have a schematic to compare their build against, no matter how simple or small.
ELECTRONERD
Joined May 26, 2009
1,147
Alright, then I'll go ahead and post it for everyone. However, this project is a progressional type of one, thus I am currently working on it with several more features. I'll post both the schematics when I finish.
Till Then,
Austin
ELECTRONERD
Joined May 26, 2009
1,147
Hey Everyone,
Here is the schematic, as requested in addition to the new code:
http://mufnet.net/index.php?show=1261
Rich (BB code):
  1. //
  2. // CreatingSound3.C
  3. //
  4. #include <p18f1320.h>
  5. #include <delays.h>
  6. #include <adc.h>
  7. #pragma config OSC=INTIO2, WDT=OFF, LVP=OFF, DEBUG=ON
  8. #define PAUSE Delay1KTCYx(50);
  9. rom const unsigned int songs[6][80] = {
  10. {0, 5, 7, 8, 10, 8, 0, 0, 5, 7, 8, 0, 8, 5, 12, 10, 12, 17, 19, 20, 22, 20, 12, 12, 17, 19, 20, 12, 20, 17, 24, 22, 12, 12, 17, 19, 20, 17, 24, 20, 29, 17, 17, 20, 19, 17, 24, 20, 17, 12, 12, 17, 30, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
  11. {500, 1000, 1500, 250, 250, 1000, 500, 500, 1500, 250, 250, 250, 250, 250, 250, 1500, 500, 1000, 1500, 250, 250, 1000, 500, 500, 1500, 250, 250, 250, 250, 250, 250, 1500, 250, 250, 500, 250, 250, 250, 250, 250, 1000, 250, 250, 250, 250, 250, 1500, 250, 250, 500, 500, 1500, 500, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
  12. {7, 9, 10, 9, 10, 12, 14, 15, 14, 12, 10, 14, 15, 14, 19, 17, 19, 12, 14, 15, 14, 30, 10, 12, 14, 12, 10, 14, 9, 10, 9, 9, 10, 12, 10, 9, 7, 9, 7, 6, 10, 9, 10, 9, 7, 6, 14, 7, 12, 10, 9, 14, 15, 17, 15, 14, 12, 9, 7, 6, 7, 30, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
  13. {500, 500, 500, 250, 500, 500, 500, 500, 500, 250, 500, 500, 500, 500, 500, 250, 500, 500, 500, 500, 1500, 500, 500, 500, 500, 250, 500, 1500, 500, 250, 500, 500, 500, 500, 500, 250, 500, 500, 500, 500, 1000, 500, 500, 250, 500, 1000, 500, 500, 250, 500, 1500, 500, 250, 500, 500, 250, 500, 1500, 250, 500, 1500, 5000, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
  14. {5, 5, 5, 3, 5, 7, 9, 9, 10, 7, 9, 10, 14, 2, 14, 9, 10, 12, 14, 14, 158, 12, 12, 14, 7, 3, 5, 5, 12, 12, 12, 12, 10, 9, 10, 10, 10, 10, 9, 7, 7, 9, 9, 2, 17, 17, 17, 17, 15, 14, 15, 15, 15, 15, 14, 12, 9, 10, 9, 7, 5, 9, 10, 12, 14, 7, 5, 5, 14, 15, 14, 12, 10, 9, 7, 5, 7, 9, 9, 20},
  15. {500, 500, 500, 1500, 250, 500, 500, 500, 500, 1500, 250, 500, 500, 500, 500, 1500, 250, 500, 500, 500, 500, 1500, 250, 500, 500, 1000, 250, 1500, 500, 500, 500, 1500, 250, 500, 500, 500, 500, 1500, 250, 500, 500, 500, 250, 1500, 500, 500, 500, 1500, 250, 500, 500, 500, 500, 1500, 250, 500, 500, 250, 250, 250, 250, 1500, 250, 500, 500, 1500, 250, 1500, 500, 250, 250, 250, 250, 1500, 250, 500, 500, 1500, 250, 1500}
  16. };
  17. void playNote(unsigned int note, unsigned int timer) // Note & Timer driver; determines which note will be played and for how long
  18. {
  19. unsigned int times, freq, notes[] = {58725, 59107, 59468, 59809, 60131, 60434, 60720, 60990, 61245, 61486, 61714, 61928, 62131, 62322, 62502, 62672, 62833, 62985, 63128, 63263, 63391, 63511, 63625, 63732, 63833, 63929, 64019, 64104, 64104, 64184, 64260, 65536};
  20. freq = notes[note]; // Determine frequency based on array value
  21. INTCONbits.TMR0IF = 0; // Clear OVF Flag
  22. LATA = 0x01; // Initialize LATA
  23. TMR0L = freq & 0xFF;
  24. TMR0H = (freq >> 8) & 0xFF;
  25. T0CON|=0x80;
  26. for(times=timer;times>0;times--) // Duration of playing
  27. {
  28. TMR0H = (freq >> 8) & 0xFF; //Load TMR0H byte first
  29. TMR0L = freq & 0xFF; // Load TMR0L byte next
  30. while(!INTCONbits.TMR0IF); // Wait for timer
  31. ` INTCONbits.TMR0IF = 0; // Clear OVF Flag
  32. LATA = ~LATA; // Invert output
  33. }
  34. PAUSE;
  35. }
  36. void playSong(unsigned int song)
  37. {
  38. int time, note, counter;
  39. while(1)
  40. {
  41. if(song==0) // Song 1
  42. {
  43. for(counter=0;counter<53;counter++)
  44. {
  45. note = songs[0][counter]; // Song 1 notes
  46. time = songs[1][counter]; // Song 1 time values
  47. playNote(note, time); // Play through notes and times
  48. }
  49. break; // When song 1 finishes, break
  50. }
  51. else if(song==1) // Song 2
  52. {
  53. for(counter=0;counter<63;counter++)
  54. {
  55. note = songs[2][counter]; // Song 2 notes
  56. time = songs[3][counter]; // Song 2 time values
  57. playNote(note, time); // Play through notes and times
  58. }
  59. break; // When song 2 finishes, break
  60. }
  61. else if(song==2) // Song 3
  62. {
  63. for(counter=0;counter<80;counter++)
  64. {
  65. note = songs[4][counter]; // Song 3 notes
  66. time = songs[5][counter]; // Song 3 time values
  67. playNote(note, time); // Play through notes and times
  68. }
  69. break; // When song 3 finishes, break
  70. }
  71. else
  72. {
  73. LATB = 0x08; // Otherwise, LED 4
  74. }
  75. }
  76. }
  77. void main()
  78. {
  79. ADCON1 = 0x0E; // ADC Settings as digital inputs from RA1-RA3
  80. OSCCONbits.IRCF0=1;
  81. OSCCONbits.IRCF1=1;
  82. OSCCONbits.IRCF2=1;
  83. T0CONbits.TMR0ON = 0; // Don't turn timer on yet
  84. T0CONbits.T08BIT = 0; // Timer0 is configured as 16-bit timer
  85. T0CONbits.T0CS = 0; // Use internal clock
  86. T0CONbits.PSA = 1; // Prescaler is not assigned
  87. T0CONbits.T0PS2 = 0;
  88. T0CONbits.T0PS1 = 0;
  89. T0CONbits.T0PS0 = 0;
  90. while(!OSCCONbits.IOFS);
  91. TRISA = 0xFE;
  92. TRISB = 0xF0;
  93. while(1)
  94. {
  95. switch(PORTA & 0x0E)
  96. {
  97. case 0x0C:
  98. LATB = 0x01;
  99. playSong(0);
  100. break;
  101. case 0x0A:
  102. LATB = 0x02;
  103. playSong(1);
  104. break;
  105. case 0x06:
  106. LATB = 0x04;
  107. playSong(2);
  108. break;
  109. default:
  110. LATB = 0x08;
  111. }
  112. }
  113. }
I also have a video of it in action:
http://s974.photobucket.com/albums/ae227/ElectroNerdy/uC%20Project/?action=view&current=PICSoundGenerator3C.mp4&newest=1
Thanks!
