I have a homework assignment working with RLC circuit analysis. Here is what the assignment says:
1. Go to URL: www.falstad.com/circuit
2. Open up the RLC Circuit. (It should be the first one that pops up, but if not go to Circuits>Basics>LRC Circuit.)
3. Change the circuit values to build an
a. underdamped
b. critically damped and
c. overdamped circuit with natural frequency of f=1000 Hz
4. Plot the natural response in both current and voltage for each of the components R L and C of the second order system when the switch is opened (6 plots total).
5. Write an equation that matches each of the plots above.
My first thoughts were to find values of R L and C by using the fact that, ω=2000∏ and that ζ must be <1, =1, and >1 for each of the different situations.
I also used the following: ω = 1/√[L*C]; ζ = (R/2)*√[C/L]
Using the tools at the above website and some other sources I was able to design an underdamped circuit with the following conditions:
R = 10 Ω; L = 100 mH; and C ≈ 253.3 nF
.: ζ ≈ 0.007921 < 1 and the circuit is underdamped.
I know that the general form for the solution for an underdamped circuit is:
x(t) = e^(-ζωt)*[A1 cos(ω*√[1-ζ^2]*t) + A2 sin(ω*√t[1-ζ^2]*t)]
I plug in what I got for ζ and ω but don't know how to solve for A1 and A2.
Now the next part is that I'm having trouble coming up with the critically damped and overdamped R L and C values while keeping the 1000 Hz frequency requirement.
For the critically damped circuit ζ = 1. I thought that I could keep L and C the same as the underdamped circuit (L = 100 mH; and C ≈ 253.3 nF) and use the equation ζ = (R/2)*√[C/L] to solve for a new resistance, R that will make ζ = 1. So I get the equation
1 = (R/2)*√[253.3n/100m]
Solve for R,
R = 2/√[253.3n/100m] ≈ 1256.6 Ω
I plugged the new R value in the circuit simulator and I can't tell whether or not it's a critically damped circuit by looking at the plots below. It's too small to tell, so I'm wondering if someone can show me how to check that or find a better way to go about doing it.
Provided that this new circuit is correct where:
R = 1262.39 Ω; L = 100 mH; and C ≈ 253.3 nF
.: ζ = 1 = 1 and the circuit is critically damped.
I know that the general form for the solution for a critically damped circuit is:
x(t) = B1*e^(-ζωt) + B2*t*e^(-ζωt)
Again, I plugged in ζ and ω but don't know how to solve for B1 and B2.
As far as the overdamped circuit goes... I haven't gotten anywhere because I am a bit confused on whether or not I'm on the right track with what I've done so far and want to see what you think.
I was going to talk to my prof after class, but he wasn't there today... go figure. Thanks for the help in advance.
a. underdamped
Solve for R,
