All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-05-2010, 09:12 PM
smartyram smartyram is offline
Junior Member
Post NAND Gate Oscillator using CD4011
I am trying to create a 1 Hertz oscillator using NAND gates.
I have created the following (image attached) NAND gate oscillator using 2 gates. Looking at the chart in the image we can notice that the input to the first NAND gate IC1a peaks at around 17v. The circuit supply voltage is 12v. When I run this simulation in Yenka the first NAND gate IC1a blows up as the input is 17-12 = 5v above the supply voltage. As the per the IC ratings in the data sheet the input pin voltage cannot be more than +/-0.5V of supply voltage.
What is wrong in this circuit?
  #2
Old 08-05-2010, 09:48 PM
beenthere's Avatar
beenthere beenthere is offline
Default
You might get better results with a different arrangement of the RC components - http://www.electronics-tutorials.ws/...ial/seq_3.html
With such a slow period of oscillation, you might also get better results with a CD4093 Schmitt trigger input NAND gate.
__________________
First comes the hardware, then the software.
The Following User Says Thank You to beenthere For This Useful Post:
smartyram (08-06-2010)
  #3
Old 08-06-2010, 12:50 AM
Audioguru Audioguru is offline
Banned
Default
Your oscillator has both inputs of the gates shorted together. If only one input is used and the spare input is connected to the positive supply voltage then the output will be more symmetrical.
I don't know why your oscillator has a switch at its output that shorts the output to ground.
Your SIM program doesn't know that the input of Cmos gates have input protection diodes that limit the input voltage to plus and minus 0.7V of the supply voltage. The 4.75M resistor limits the current in the input protection diodes.
The Following User Says Thank You to Audioguru For This Useful Post:
  #4
Old 08-06-2010, 03:11 PM
Junior Member
Default Modified design
Hi Audioguru,
I changed the circuit as per your suggestion. I got rid of the switch that shorts the output to ground, was using it as a reset. I still notice the output in the simulator is same. Any thoughts?
I read about input protection http://www.fairchildsemi.com/an/AN/AN-248.pdf. So that means the additional ~5v at the input should not destroy my CD4011 NAND gate right?
Ram
  #5
Old 08-06-2010, 06:01 PM
Junior Member
Default Using CD4093 Schmitt trigger input NAND
Hi beenthere,
I have made a new circuit. Would appreciate any feedback from you? The wave is not exactly square in shape. Is it good enough to run a binary counter?
Thank you
Ram
  #6
Old 08-06-2010, 06:43 PM
Banned
Default
Your simulation software is wrong because it shows the input going 4V higher than the positive supply and 4V below ground.
The diodes at the input protection of Cmos gates clamps the input voltage to 0.7V higher than the positive supply and 0.7V less than ground, especially since the oscillator has a very high value resistor (4.7M) feeding the input.
Your simulation sofware is also wrong when it shows the very slow switching ramps (0.05 seconds) produced. The datasheets of Cmos gates shows that they switch their output in only 50ns (0.0000005 seconds).
Why do you use a very high value resistor (1M) feeding the oscillator to the counter's clock input? The resistor is not needed if the ICs use the same power supply voltage.
  #7
Old 08-06-2010, 06:47 PM
Jony130 Jony130 is offline
Default
Maybe it will be simpler to use 4060.
You get oscillator and counter in one.
And for 1Hz in Q14 you need CT=22nF and Rt=1.2K.
Or try 4541
The Following User Says Thank You to Jony130 For This Useful Post:
  #8
Old 08-06-2010, 07:50 PM
Junior Member
Default
Or try 4541
I need a 12 stage counter and cannot use 4060 as it is 14 stage. As for using 4541 I think it will be an overkill for my circuit. I am using this oscillator to drive a clock pulse to a bigger circuit. I have few spare NAND gates in my bigger circuit and decided to use them for generating the clock pulse.
  #9
Old 08-06-2010, 07:59 PM
Junior Member
Default
Quote:
Originally Posted by Audioguru View Post
Your simulation software is wrong because it shows the input going 4V higher than the positive supply and 4V below ground.................
You maybe right, Yenka the simulation software I am using may not be up to snuff. I guess i will have to try the thing out on a breadboard and see if it works or it blows up the CD4011.
I put in the 1M resistor between the oscillator and the counter to isolate the oscillator from the load (the counter). I saw this technique somewhere in a circuit. You think the resistor is a waste?
  #10
Old 08-06-2010, 08:30 PM
Banned
Default
Your Yenka sim software doesn't know if it is coming or going.
A CD4011 will not blow up unless you connect the power supply backwards.
The 1M resistor between the oscillator and counter is not required and might stop the circuit from working because it will combine with stray capacitance between wires and cause the square-wave from the oscillator to be a triangle-wave at the clock input of the counter.
Tags
Related Site Pages
Section Title
Worksheet CMOS logic gates
Worksheet Basic logic gates
Worksheet Design Project: Logic probe
Textbook NAND gate S-R flip-flop : Digital Integrated Circuits
Textbook Basic gate function : Digital Integrated Circuits
Textbook Logic signal voltage levels : Logic Gates
Textbook Gate universality : Logic Gates
Textbook CMOS gate circuitry : Logic Gates
Textbook TTL NAND and AND gates : Logic Gates
Textbook Multiple-input gates : Logic Gates
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
