hi guys, motor specs: ~10amp, 115vac 72s/20r mfd 480v capacitors. so ill get to the point i want to try and run it with only the run capacitor. today i tried it and when i set everything up the motor turned slowly then the circuit breaker went off. now i think there could be 2 reasons for this, 1 being in my title (no start capacitor--the motor wont be under load (only its own) while starting) but i also used low gauge (22 i think) wire to just test it because the motor is on a plug which i don't want to cut just yet, so i used the low gauge just for testing. so my question would the motor turning slowly then blowing the breaker be caused by the no start capacitor, incorrect wiring (im gonna try thick gauge tomorrow) or both? is there a way to only use the run capacitor? it'll save me a few bucks on a low budget project thanks in advance, david
