Hello all,
I've built a circuit that allows controlling one (or more) ATX Power supplies automatically from one "Master", which automatically turns on the "Slave" PSU(s).
This is done with only a few basic parts.
The attached schematic shows the circuit.
Notes: the 470 Ohm resistor can probably be swapped with a 390 Ohm, if none are on-hand...
And the Green LED can be changed to any other kind (also be sure to change the resistor connected to it to match the LED's voltage)
ATX Pinout here:
http://pinouts.ru/Power/atx_v2_pinout.shtml
- 2 Resistors
- 1 Optoisolator
- 1 LED
- 1 Molex 'Male' connector.
- 1 ATX 20/24 pin "Extension" cable
ATX Pinout here:
