Hello to all,
I'm having trouble finding out the "pinout" of a A933 PNP transistor.
The manual says
Here is the picture of A933:
What do "S" and "R" stand for ... "Set" and "Reset" as in SR latch? And "J"? Should these tell me which pin is E, C and Base?
Or is there some convention that, no matter the transistor type/model, "flat side" is the side with label on it?
Thank you for helping a humble novice.
The manual says
But (as far as I can see) A933 is flat on both sides!Transistors have 3 pins named emitter, collector, and base, from left to right with the flat side facing you. [...]
