All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Radio and Communications
Notices
Radio and Communications Discussion forum for all aspects of RF and communication engineering, including antennas, modulation regimes, RF circuits and filter design, and telematics.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-21-2010, 12:17 PM
elisettynarendra elisettynarendra is offline
Junior Member
Default end effect in antennas
can anyone explain what is end effect in antennas ?
how it effects the antenna performance ?
  #2
Old 07-21-2010, 04:27 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
An antenna is an arrangement of conductors designed to radiate RF energy. The impedance of an arrangement of conductors can be calculated or measured at any point along those conductors. When you get to the end of a conductor there is an impedance discontinuity. At an impedance discontinuity there are two things that happen to waves, as dictated by the wave equation: transmission and reflection. Some of the RF power goes through the discontinuity and some of it is reflected back to the source.
Impedance discontinuities happen at other places besides the end of a conductor. The other thing to keep in mind is that, "The RF gotta' go somewhere".
__________________
We never have time to do it right,
But we always have time to do it over.
  #3
Old 07-21-2010, 07:28 PM
KL7AJ KL7AJ is offline
E-book Developer
Default
The end effect of an antenna is an effective capacitance which makes a dipole antenna effectively slightly longer. A half-wave resonant dipole is going to be slightly less (about 5%) than a half wavelength in free space. If the wire were infinitely thin, there would be no end effect, but the two halves of a dipole act like small capacitors across the feedpoint.
The general rule for a thin-wire dipole is: L (feet)= 468/Freq (Mhz) This formula takes into account the end effect. Without end effect it would be 492/freq.
Eric
__________________
REAL men don't need voltmeters.
  #4
Old 07-21-2010, 07:30 PM
Papabravo's Avatar
Default
You said:
tnx for ur reply sir
but i have a doubt regarding its relation (end effect ) with antenna length.i got from a book that ' beacuse of end effect the effective length of antenna is less than actual length ' is this beacuse of reflected power causing standing waves ?? plz exlpain sir.
I don't answer private messages, I only answer in the open forum:
The end effect changes the complex impedance of the antenna/feedline system so that the resonant frequency occurs at a shorter physical length than the one half wavelength predicted by theory without end effect. I believe the end effect is effectively modeled by an additional lumped capacitance.
__________________
  #5
Old 07-22-2010, 02:10 AM
Junior Member
Default
tnx for ur reply
would u please suggest best book for antennas? if possible links
thanks in advance
  #6
Old 07-22-2010, 05:47 PM
Papabravo's Avatar
Default
ARRL Antenna Handbook is an excellent practical resource. They tend to be short on the theoretical underpinnings of the construction projects.
__________________
  #7
Old 07-22-2010, 06:23 PM
bertus's Avatar
bertus bertus is online now
Administrator
Default
There is also the website of AC6V with a special page on antenna projects:
http://ac6v.com/antprojects.htm
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
Tags
Related Site Pages
Section Title
Textbook Waveguides : Transmission Lines
Textbook Impedance transformation : Transmission Lines
Worksheet Fundamentals of radio communication
Textbook Standing waves and resonance : Transmission Lines
Textbook ``Long'' and ``short'' transmission lines : Transmission Lines
Textbook Finite-length transmission lines : Transmission Lines
Worksheet Characteristic Impedance
Textbook More on the ``skin effect'' : Reactance And Impedance -- Inductive
Textbook Principles of radio : Basic Ac Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
AC/DC hall effect sensor circuit frascati General Electronics Chat 36 02-10-2014 11:27 PM
Dual band antennas? skybox General Electronics Chat 3 05-28-2010 03:31 PM
I2C and UART Protocol with FT2232D chip mainevent Programmer's Corner 0 05-11-2010 01:50 PM
some weird effect of Telephone DTMF MT8870CE !!! vinodquilon General Electronics Chat 10 02-26-2010 12:33 AM
Loading effect raghuveer General Electronics Chat 1 06-10-2008 07:03 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
