it's complicated,,, i'm just starting at digital circuitsYou could try the following:
Your outputs for the hour digits are 4-bit numbers, right? The difference between 12 hour and 24 hour system is that numbers past 11 don't show up in the 12 hour system. So, recognise numbers past 11 and substract 12 from them.
The logic test is this: Let H4,H3,H2,H1 be the decades number and L4,L3,L2,L1 be the units number. Numbers past 11 (12,13,14...) satisfy the function F=(H2+H1)*(L4*L3*L2)'. Feed this signal on the enable pin of 2 4-bit adders (or 1 of 8-bits), and substract 0001 0010 from them. This will be done by actually adding their complement of 2, 1110 1110. You don't need to compensate for a possible result of above 1010, as no half bit number is larger than 1100 to yield an invalid BCD result.
This might sound a little complicated, so feel free to ask about anything you don't understand.
PS: BCD represantation can be a bit tricky, but it's worth the trouble!
if i use this ic will the 10 be gone... isn't it going to be 01 02 03 04 05 06 07 08 09 11 12???Basically start from scratch and design a two digit counter that counts from 1 to 12. You will use gates to look at the logic conditions to do the appropriate resets (presets actually, since it needs to reset to 1).
There is a TTL chip out there that will do this, the 74192 (datasheet attached).
Interesting thing about the 74192, you can preload the registers to any number you want (they call this presetting). This feature is useful to make something similar to a reset that goes to 1 instead of zero.
We have had a lot of homework assignments for using clocks and this IC.
You seem to have focused on the TTL stuff, which is positively ancient. The CMOS series (4000 and 4500 families) have very close equivalents if you need to use a more modern chip, though those are considered obsolete nowdays too.
Like I said in the other post, some reading required. The good news is, while not being extremely advanced, it is extremely useful knowledge, something you will need forever if you keep working with digital logic.
A binary counter counts from 0 to F; a BCD counter (BCD is worthwhile to learn about) counts 0 to 9.if i use this ic will the 10 be gone... isn't it going to be 01 02 03 04 05 06 07 08 09 11 12???
how can i set ' 192 to 1 2 3 4 5 6 7 8 9 0 1 2 then 1 2 3 4 5 6 7 8 9 0 1 2 again??This is where your training with gates come in. Remember, these counters are fundamentally binary. The most significant digit is a simple flip flop, unless you want to create an option for a 12 or 24 hour clock. The logic for each is totally different. However, with gates, you can make it optional (a common option for clocks).
Starting from a fresh count...
0 0001 .. 01
0 0010 .. 02
0 0011 .. 03
0 0100 .. 04
0 0101 .. 05
0 0110 .. 06
0 0111 .. 07
0 1000 .. 08
0 1001 .. 09
1 0000 .. 10 .. Note 1
1 0001 .. 11
1 0010 .. 12
1 0011 .. 13 .. Note 2
Note 1: A BCD counter will reset on 10, and sent a carry signal to the next stage. Look for this on the datasheet.
Note 2: A simple 3 input AND gate can sense the number thirteen, this is used to send a reset signal to the most significant digit (the simple flip flop) and a preset signal to the 74192, taking it back to the number 1. I have highlighted the digits used in the reset signal in red.
Side note, I regularly use diode gates in my designs. They lay out easier, and work. Just mentioning this as an option for you too.
Or in his case, 0001.Be a bit more patient. Wait more than 5 minutes.
Presetting on the 74193 chip is easy enough to explain with the datasheet:
http://www.datasheetcatalog.org/datasheets/90/248169_DS.pdf
Pull the LOAD pin high for normal operation. You load data, put the data you want on Data A, Data B, Data C and Data D, then pull LOAD low. When LOAD goes low, the data is loaded into the flip flops.
You could have learnt this from the third paragraph of the summary.
So basically, use a triple input (N)AND gate on the output, as Bill suggested, feed this to the LOAD pin with 0 0 0 0 on the data pins.
by Duane Benson
by Jake Hertz
