I continue to have a need, in the course of my invention's development, for what I would call a "terminal strip" or "base strip", but with one caveat: all the positions should be already connected together. And I'm not talking about the large black terminal strips with the exposed screwheads. I know there are jumpers for them, but the connections are unacceptable for me, and they are really too big and ungainly for my purposes. I'm also not talking about the white plastic "European Style" terminal strips (although if they sold jumpers for them, I might consider it).
I'm attaching a picture of an MCVU product from Phoenix Contact. It's designed to mount on a panel or whatever, and there is a mating plug that you insert into it. The pitch is 3.81 mm, but anything from 2.5 mm to 7 mm would probably do. I called PC again today, expressed my need, and again they told me they don't have any such thing. I just need something similar to this (doesn't have to be "pluggable"...could be terminal block style), but where all the positions are already connected to each other internally.
The reason I need this is that I have a "box" which might have a circuit board near one end that has an output (say...a regulated 12V voltage) destined for 3 components (maybe an electronic filter, a motor driver, etc.) on the other end of the box. And rather than find a way to divert the 12V output into 3 or 4 parallel outputs, and then run 3 or 4 separate wires across the box, it would be much cleaner and easier to just run one wire across the box, to some sort of a "landing area". This "landing area" is what I need. So the wire would come into one pole of the "equi-potential base strip", and then 3 or 4 wires would emanate from other poles to their corresponding nearby components.
I keep running into this need, and yet, the guy at Phoenix Contact told me today that he has never had a request for such a thing. I don't really understand that. Maybe I am doing something wrong....LOL. But if anyone has any ideas for this, I am in great need of them! Thanks a lot.
