Hello, everyone.
I am reading the material on this website, and have a question regarding grounding, discussed here:
http://www.allaboutcircuits.com/vol_1/chpt_3/3.html
I understand that the purpose of the grounding point is to make any person standing on the ground electrically common with earth ground, and that there is no voltage between electrically common points.
What I fail to understand is the specifics of how this helps.
The book gives scenarios to illustrate the potential danger in not grounding a circuit: if a tree touches the wire, and creates a ground path, then when a person standing on the ground also touches the wire, the circuit is complete, and the person will be shocked.
The second of these scenarios involves a case where there are two people, each standing on the ground. One touches the high wire and one touches the low wire. A tree touching the high wire completes the circuit for the first person, through a ground path. But the second person is also shocked, since the two people are both touching the ground.
What I fail to understand is how adding a ground wire would solve the problem! In all of the danger scenarios that the book depicts, I don't see how adding the grounding wire would prevent the shock.
I thus fail to understand how in any scenario, a person would receive a shock in the absence of a grounding point, but due to the grounding, the person does not receive a shock.
