All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-24-2010, 05:39 AM
himanshu1990 himanshu1990 is offline
Junior Member
Default dual axis solar tracker (mppt)
hey there seniors....
m preparing a solar tracking device that i have to finish within this week..
i have already completed the major portion...
plz see attachment...
bt i want to make two improvements...
1.)incorporate another two LDR's for season mounting...
2.)incorporate a dc to dc converter (variable duty cycle) for MPPT...
the circuit shows for a single motor...
kindly advice...
thanx....
  #2
Old 06-24-2010, 05:40 AM
Junior Member
Default
sorry.... m using an 89c2051 controller....
  #3
Old 06-24-2010, 05:57 AM
Vasanthkini Vasanthkini is offline
Junior Member
Default
I can help you on DC-DC converter.Can you elaborate a little more on what exactly are you looking for?
Thanks!
The Following User Says Thank You to Vasanthkini For This Useful Post:
himanshu1990 (06-24-2010)
  #4
Old 06-24-2010, 07:24 AM
Junior Member
Unhappy
hey thanx vasanthkini...
i need a dc\dc converter for maximm power point tracking of the solar tracker....
by varying the duty cycle of the dc\dc conv. we make sure that the solar panel sees a load that corresponds to the maximum power point.....
by varying the duty cycle we bring the load line for the solar panel to the point where it gives max output power....
plz refer to the attachment for further assistance
I am looking for some circuit for that takes little power and has an adjustable duty cycle...
i am using a crystal oscillator for the controller so i wont be able to use that for the dc\dc conv. as it gives fixed frequency oscillations ...
but i need to take up minimum hardware...
that's what i am asked for...
  #5
Old 06-24-2010, 08:46 AM
Junior Member
Default
Hey !
I get what exactly you are looking for.I have worked on these projects quite a lot.Varying the duty cycle is simply nothing but PWM technique.Please give me the spces of the converter and ill help you proceed further.
Thanks !
  #6
Old 06-24-2010, 05:02 PM
Junior Member
Default
hey sir..
sorry for replying so late...
well...
there arent any specifications as such..
all i want to do is install a dc/dc conv in bw the load and the solar panel...
this matches impedance levels so that the quiscent point is at the maximum power point...
for that we need a variable duty cycle converter...
so do i have to install a multivibrator or an oscillator that gives variable oscillations...
plus I am using a crystal oscillator for the controller...
is there a way so that i can make the controller use the const duty cycle oscillator output and use the same as the variable duty cycle input to the converter..?
I may not be using a PV panel anyways coz of limited funds...
i am jst preparin a prototype for the sun tracker that tracks the sun for max. open circuit output and uses dc converter for maximum power point trackin.....
plz suggest if there are ny limitations associated...
thanx....
  #7
Old 06-25-2010, 05:43 AM
Junior Member
Default
Dear Himanshu,
A converter will have a input voltage and required out put voltage.With out these details,how would you be able to design a converter?From the solar panel,as per the panel you will have a certain amount of voltage that goes to the input of the converter.This can be stepped down or stepped up as per the requirement,which then goes to your load.We employ PWM tech to vary the duty cycle which is achieved by using a power switch.If you are looking for just the theoretical part of the converter,then let me know.
Thanks!
  #8
Old 06-27-2010, 05:20 AM
Junior Member
Default
HI SIR
just as i told you i havent actually thought to install a solar panel as such...
becoz of limited funds..
so i really dont know about the ratings and all..
let us assume that we have a solar panel that can give an optimal output....
and we are driving a dc bulb...or something then what can we use....??
plz suggest....
  #9
Old 06-27-2010, 07:19 AM
retched's Avatar
retched retched is offline
Default
Well typically you would use a DC to AC inverter so you could use standard appliances with the solar panels.
If this is a mobile unit, used to pump water or light a cave, you need:
Solar panels,
charge controller,
batteries
That is all you need to run DC stuff... well you will still need to get the DC to the required voltage for the task.
__________________
-rm-
  #10
Old 06-27-2010, 10:26 AM
Junior Member
Unhappy
hey there retched...
the problem is that by using a dc/ac inverter the panel wont reach maaximum power point...
plz refer to the previous replies of this thread and their attachments....
Tags
Related Site Pages
Section Title
Worksheet Signal modulation
Worksheet Power conversion circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need Help with solar tracker! mikeknight Embedded Systems and Microcontrollers 13 05-19-2012 04:58 PM
Help with solar tracker electronicsnewbie The Projects Forum 7 01-18-2010 02:48 PM
An intelligent solar tracker (read 1st post first) umer27 The Projects Forum 12 03-07-2009 08:03 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
