All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-23-2010, 02:24 PM
tgarrity tgarrity is offline
Junior Member
Default Replace Transformer for Cordless Drill Battery Charger
Hello there. I have a cheapo 18v cordless drill from Menard's and the battery charger supply went bad. I determined that the primary winding of the transformer is open. The specs on the outside of the transformer shows 24vDC output. My question is, if I can find a replacement transformer, does it need to be higher than 24vAC output in order to produce the required voltage to recharge the 18v battery? (I'm assuming U.S. AC line voltage input.)
I remember the .707 RMS calculation from my electronics school daze, but
I looked at the lessons here in AAC and it shows DIVIDING by .707 for a full wave bridge rectifier (my case) produces a HIGHER voltage than the AC secondary transformer output. So I'm confused. I would think the average DC output would be LOWER due to loss in the sine wave output, and I would think you would MULTIPLY by .707.
In any case, what size transformer do I need? Any help is appreciated.
Thanks,
Terry
  #2
Old 06-23-2010, 03:34 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Yep, it's RMS/.707107 - or RMS * 1.414
You'd need to subtract the Vf of the rectifier diodes as well; roughly 0.7v at their rated current for standard silicon diodes. If you are using a full wave bridge (4 diodes) then it's roughly 1.4v. If you're using a CT secondary and 2 diodes, then it's just the 0.7v loss.
It would help a lot if you posted clear photos of your existing circuit board, top and bottom.
It's hard to take good photos of boards. Best lighting is outside on an overcast day; if it's clear weather drape a white sheet over yourself and your subject to diffuse the light. Don't use a direct flash; the picture will be very harsh and contrasty.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #3
Old 06-23-2010, 03:38 PM
Bernard's Avatar
Bernard Bernard is online now
Default
I would try for a 24V secondary @ 1/2A to 1A & not worry about the math as we do not know how much filtering or regulation is used.
The Following User Says Thank You to Bernard For This Useful Post:
tgarrity (06-23-2010)
  #4
Old 06-23-2010, 04:00 PM
Junior Member
Default
Wait a minute. You want me to go OUTSIDE with a white sheet over my head???? Are you trying to get me killed??
  #5
Old 06-23-2010, 04:03 PM
Junior Member
Default
Thanks Bernard. There is NO filtering that I can see. Just a small circuit board with 4 diodes attached to the secondary. That's it. Just didn't know if I needed a higher secondary output to compensate for the effective RMS voltage. Thanks!
Quote:
  #6
Old 06-23-2010, 04:22 PM
SgtWookie's Avatar
Expert Member
Default
Ahhh, better get the current rating from the original transformer, and match it up.
What's the current or VA or Watt rating of the original transformer? It's a wall-wart, right?
The likely problem with your transformer is that the thermal fuse opened up due to overheating. The overheating might be caused by too much of a load on the output (batteries shorting internally) or the transformer windings are starting to short out, or one or more of the diodes in the output bridge are shorted.
Better check everything out before you slap a new transformer in there and burn it up as well.
__________________
General info:
  #7
Old 06-23-2010, 04:39 PM
Junior Member
Default
Thanks SgtWookie. I don't have it with me, but I believe it was somewhere in the neighborhood of .5 A. It's a Coleman drill from Menard's (home improvement store), but el cheapo. I dissected the top layer of teh transformer and there appears to be a 2K resistor that is open. A tech I talked to here at work said it was probably to act as a fuse. I checked the diodes, they are OK. I can believe the batteries might be toast. They are NiCd. Or maybe it was CHEAP. There's a surplus store here that sells just about every kind of transformer you'd ever need, and they are cheap, so worth a shot. Thanks guys!
  #8
Old 06-23-2010, 05:05 PM
SgtWookie's Avatar
Expert Member
Default
Try replacing the 2k fuse with one of the same or next higher wattage.
If you simply use another transformer without the current limiting, you'll fry your batteries.
__________________
General info:
  #9
Old 06-23-2010, 07:30 PM
Junior Member
Default
I can't get inside of it enough to replace the resistor. It looks like they encased it after soldering the fuse inside. I can't see of a way to get at it without destroying it.
  #10
Old 06-23-2010, 08:32 PM
SgtWookie's Avatar
Expert Member
Default
Yeah, they do that.
Well, if it was in fact a 2k resistor, that's a bit odd - but it would serve to limit current on the primary side, rather than having to regulate the secondary side.
What kind of batteries does the drill use? NiCD? NiMH? LiPO? Any clues?
__________________
General info:
Tags
Related Site Pages
Section Title
Worksheet Basic AC-DC power supplies
Worksheet Performance-based assessments for AC circuit competencies
Worksheet Advanced electromagnetism and electromagnetic induction
Textbook AC voltmeters and ammeters : Ac Metering Circuits
Textbook Special transformers and applications : Transformers
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Textbook Other waveshapes : Mixed-frequency Ac Signals
Video Lecture Power Supplies - Applications - Diodes and Diode Circuits
Textbook Input and output coupling : Bipolar Junction Transistors
Textbook Rectifier circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
battery charger questions mrel General Electronics Chat 5 02-21-2010 03:23 PM
solar powered smart battery charger salamander27 The Projects Forum 21 05-28-2009 11:13 PM
Li-ion Battery Charger and Laptops iONic The Projects Forum 7 12-27-2008 10:43 PM
Battery pack charger remake from 18V to 6V (or other) eimix General Electronics Chat 7 10-09-2008 08:45 AM
ALKALINE BATTERY CHARGER lildiesel6075 The Projects Forum 32 06-22-2007 12:51 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
