Greetings one and all ...
I recently decided to refurbish the interior of my '91 Toyota MR2 and decided that I would like to 'flock' the dash, centre console and other bits etc to inprove things. As this is all I have in mind, buying a professional flocking applicator seems a little extreme at around £700 a pop !! So, I started looking round to evaluate the possibility of building a unit myself ... give the limited use it will get.
The problem I've encountered is that most of the stuff out there on the 'Net seems to be quite old and much of the schematics and component used appear to be based upon older, and now unavailable items or steam driven technology. I have tried looking at buying a 'kit' (based upon the Cockroft-Walton Multiplier pricipal) but the supplier can't/won't quote a figure for the output (needs to be in the range of about 35KV + pullin' about 40 micro amps if I use battery power (6 or 9VDC) although mains power (230VAC) would be preferable) and it seems like a bit of a waste of money to have to buy the kit in order to establish the output !?!
Now I must add at this point that my experience of High Voltage applications is ZERO !!!! ... so I'd be most grateful for assistance with the following ....
... I came across an article which appears to describe a circuit which meets my needs almost exactly, trouble is that some of the components appear to be unavailable (due to age of article) and a bit of the circuitry leaves me mystified; so ... and here's the big ask ... would one or other of you kind souls care to step up to the plate and update what I've found so that I can have a fighting chance of building it ??? ... PLEASE
My main sourcing issues seem to be mainly associated with; C2, L2, T2 and Thy1 (have the pdf spec sheet if required)
Thy1 Thyristor S0802MH by Tag Semiconductors Ltd (pdf spec sheet available)
T2 Transformer 240v : 240v 12vA type DB247
T1 Motorbike ignition coil from any bike repair shop or scrap yard
Here's the circuit diagram I found ...
... and here's the info that went with it ...
For safety, a 240:240 volt mains isolating transformer is used. This could be replaced with a 240:350 volt transformer to increase the output voltage but you would have to make other changes to compensate.
The isolated AC mains voltage is full-wave rectified by diodes 1 - 4 to produce positive going sine waves at 100 Hz. Each one charges up capacitor C1 and , as the voltage reaches its peak, the thyristor switches on to discharge the capacitor through the ignition coil primary. The rapid change in current induces a voltage of around 30kV peak on the coil primary. This voltage pulse is connected via 30 diodes to a metal plate which acts as a capacitor and holds a positive charge with respect to ground. The diodes each have a reverse breakdown voltage of 1000 volts minimum.
Resistor R1 limits the current flowing through the thyristor when it turns on. The resistor chain formed by R2, R3 and R4 sets the point on the sine wave when the thyristor turns on. Ideally this should be close to the peak but some allowance must be made for locations where the mains voltage is less than the nominal 230 volts. The value of R4 can be altered to change the switching point. If a 350 volt transformer is used, the value of R4 can be reduced accordingly, so that the thyristor switches closer to 340 volts than 230.
Please note that resistors R1, 2 and 3 are high voltage resistors rated at 350 volts. You should use the ones specified as ordinary resistors could break down.
C1 is chosen for its ability to withstand the rapid change in voltage (dv/dt). If you use a different type from the one specified, it may not survive.
C2 and L2 are included to minimise the "noise" going back to the electricity supply. Neither these, nor the transformer, T2, are required for correct operation but they are essential to meet the best safety and emission requirements. (Note that they may not be sufficient to meet CE and other legislation so please do your research carefully if you plan to manufacture equipment based on this prototype.
Switch S1 is a press-on release-off type for safety. This ensures that you always have one hand on the switch while the unit is running. The switch has an insulating plastic cover fitted.
