All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-27-2006, 07:37 PM
kevy kevy is offline
Default power supply for plus and minus 12 V dc from 240V ac
I am a college student need to build a power supply for my project.
The project is require the + and - 12V dc.
I need to convert the housing voltage (240V AC) to plus and minus 12V DC.
I am looking for guidance.
Can someone teach or provide me the schematic diagram on how to contruct a circuit for this power supply?
  #2
Old 11-28-2006, 02:02 AM
wireaddict wireaddict is offline
Default
You didn't specify whether you wanted the 12 VDC outputs regulated or not; if you don't need regulation go with a transformer with an 18 to 20 V center-tapped secondary. If you need regulated 12 V then get one with 24 V. Mouser Electronics [www.mouser.com] has a good assortment of transformers including some with dual primaries which operate on 120 & 240 VAC [as shown in the sketch].
The filter caps can be about 25 working volts; observe polatity when connecting them. If you want regulate the outputs connect a 7812 between the positive 12 to 17 V terminal & common, & a 7912 between the negative 12 to 17 V terminal & common.
Dave
  #3
Old 11-28-2006, 09:22 AM
Gadget Gadget is offline
Send a message via MSN to Gadget
Default
You also dont let us know what sort of current you want out of it.
Most kitset suppliers would have something that would do the trick for up to 1 amp. Locally, Jaycar have a + & - 15 volt supply PCB, which will do fine if you replace the 7815/7915 regulators with the 7812/7912 regs mentioned by Wire addict. A 24 - 30 volt centre tapped transformer with that modified PCB would work just fine.
Tags
Related Site Pages
Section Title
Worksheet Negative feedback opamp circuits
Worksheet Power conversion circuits
Worksheet Class A BJT amplifiers
Worksheet Basic AC-DC power supplies
Worksheet Autotransformers
Worksheet Step-up, step-down, and isolation transformers
Textbook Special transformers and applications : Transformers
Textbook The common-collector amplifier : Bipolar Junction Transistors
Textbook Rectifier/filter circuit : Discrete Semiconductor Circuits
Textbook Transformer -- power supply : Ac Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Submission: Power Supply Circuits Bill_Marsden Feedback and Suggestions 50 07-30-2012 10:50 PM
A little help needed with LM741 dual tracking power supply knoba The Projects Forum 11 05-04-2012 07:09 AM
Plus and minus 18 volt DC power supply crankcase General Electronics Chat 6 09-10-2011 04:33 PM
Creating a Virtual Power Supply Article. Bill_Marsden General Electronics Chat 10 01-02-2009 05:20 AM
DC power supply module For HP 1610 Gompers General Electronics Chat 7 03-12-2008 01:36 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
