| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
Hi
I need to connect 2 decoders 3x8 (SN74LS138) to get a decoder 4x16 but I don't understand wich enable pin should be connected to join the IC. Could somebody help me? Thanks |
#2
If the lines you are decoding are D, C, B, A; then connect C, B, A to the pins with that label on both of the 74LS138 chips. Connect D to G1 on one of the decoders, and on that same decoder connect G2A and G2B to logic low(GND). On the other decoder connect D to either G2A or G2B, and connnect G1 to logic high, and which ever of the G2 inputs you did not connect to D should go to logic low(GND)
Both decoders should be enabled all the time and you have a 4 x 16 decoder. |
#3
You should connect the three input bits in parallel, and the fourth to one decoder and its negation to the other enable pin to switch the lower eight and higher eight outputs.
| Tags |
| 4x16, decoder, urgent |
Related Site Pages
| Section | Title | |||
| Worksheet | Performance-based assessments for digital circuit competencies | |||
| Worksheet | Counters | |||
| Worksheet | Digital display circuits | |||
| Worksheet | Multiplexers and demultiplexers | |||
| Worksheet | Encoders and decoders | |||
| Textbook | Ring counters : Shift Registers | |||
| Textbook | Parallel-in, parallel-out, universal shift register : Shift Registers | |||
| Textbook | Serial-in, parallel-out shift register : Shift Registers | |||
| Textbook | Decoder : Combinational Logic Functions | |||
| Textbook | 7-segment display : Digital Integrated Circuits | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Help, designing a keypad matrix decoder | fyanardi | Homework Help | 3 | 06-08-2009 04:22 AM |
| Urgent help on phase shift oscillators | cmy | Homework Help | 0 | 11-01-2006 01:16 PM |
| Urgent help required in Designing a Decoder. | m_roy | Homework Help | 2 | 11-01-2006 01:03 PM |
| Small project:binary to 7segment decoder (simplification) | Yarrow | The Projects Forum | 8 | 09-29-2006 01:05 PM |
| Thread Tools | |
| Display Modes | |
