All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-22-2004, 09:34 PM
Iwan Iwan is offline
Junior Member
Default
Hi....
can someone explain to me how PNP transistor works?I know about NPN transistor.
When i see the structure the NPN have great amplifying in the emitter.But the question about PNP the current are flow to base right.Is the structure of PNP different with NPN?Is the base region are bigger than emitter or collector?
Plz someone explain the PNP transistor to me .
  #2
Old 08-24-2004, 03:55 PM
Mjollnir Mjollnir is offline
Junior Member
Default
I just studied this last semester
with the PNP, Current enters tru the emitter and leaves tru the base and collector
Base region is highly negative doped, and very thin, so hardly any recombination occurs and most carriers drift across it into the deleption region on the C collector side. E and C are postively doped
IE = IC + IB = (beta +1) IB still holds, except now current enters tru the emitter
in order for the PNP to be in forward active region, u need to bias it such that VBE = -0.7V and VCE = -0.2V
this makes the Base Emitter P-N in forward bias. The VCE biasing setup an electric field to sweep the carriers out of the deleption region on the collector side, also to prevent Collector Base P-N junction conducting in forward bias.
  #3
Old 08-28-2004, 03:08 AM
mozikluv mozikluv is offline
Default
hi
let me add a little about the workings of BJT NPN & PNP. everytime we see a bjt transistor symbol we always use the arrow symbol to identify the transis whether it's npn or pnp.
but we sometimes forget that the arrow also represents the current flow direction and when we look at a schem it makes it easy to follow how the current flows in a circuit. that arrow direction guides us how the control current and the working current flows.
for npn, the arrow points away from the base and collector so the control current flows into the base and goes into the collector but goes out the emitter and the working current flows into the collector and goes out the emitter. while for pnp, control current flows into the emitter and goes out of the base and the working current flows into the emitter and flows out the collector.
when an arrowhead appears in any semiconductor symbol it always represent a PN junction and it points from P to N. as a general rule for PN junctions current is permitted to pass from P to N but blocked if it tries to pass from N to P.
__________________
THE BIGGEST ROOM IN THE WORLD IS THE ROOM FOR IMPROVEMENT
Tags
Related Site Pages
Section Title
Worksheet Conventional transistor overview and special transistors
Worksheet Class B BJT amplifiers
Worksheet Bipolar junction transistor theory
Textbook The Shockley Diode : Thyristors
Video Lecture Bipolar Transistors (intro) - Transistors and Transistor Circuits
Textbook Meter check of a transistor : Bipolar Junction Transistors
Textbook The transistor as a switch : Bipolar Junction Transistors
Textbook Introduction : Bipolar Junction Transistors
Textbook Thyristors : Solid-state Device Theory
Textbook Bipolar junction transistors : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
Transistor Question TomWhitfield General Electronics Chat 13 04-06-2013 06:59 PM
Transistor turning off instead of on through op amp Trike007 The Projects Forum 17 09-27-2012 04:52 PM
For Single transistor Amplifier for Mobile. anil007 General Electronics Chat 0 07-24-2012 06:25 AM
transistor connected to actuator J.Green The Projects Forum 17 06-06-2011 03:23 PM
Austin's Transistor Dossier: An Analysis of Transistor Design ELECTRONERD General Electronics Chat 72 11-25-2009 11:49 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
