Phase Shift Oscillator
traitorousdevil
Joined May 24, 2010
15
Hi...
According to the attachment, I'm wondering... If I would just want the phase to be shifted 120 degree only, is it that possible with I'm using 2 pair of RC?
If it is possible, what will be the value of both pair of RC pair? Is that can be calculate through any calculation or...? The output frequency I wish to get is just 50Hz which is similar with my input frequency as well...
Thanks... =)
SgtWookie
Joined Jul 17, 2007
22,230
Jim,
You seem to be working pretty hard on this.
What's your ultimate goal? A 3-phase output?
It would help us a lot to help you more quickly if we know for sure what you need.
Phase shifting by a given amount of degrees is usually easier if it's done in a loop.
traitorousdevil
Joined May 24, 2010
15
Yupz... The 3 phase output with each 120 degree phase shift...
I'm trying combining 3 phase shift oscillator to convert the single phase to 3 phase... Although I'm not sure would it work... =P
I have a confusion here... Where is the input for the oscillator in previous post's attachment? I have been searching lots of phase shift oscillator circuit but none of them shown the position of input signal should be...
traitorousdevil
Joined May 24, 2010
15
I have done my circuit~! But there's some problem...
As shown in attachment, my output voltage is damn low... what changes can i make 2 increase the output voltage... Also, the 3 output have different voltage... Any ways to make 3 of them have similar voltage range? * 0v-20V
Next, that's the problem for my 3rd output... Why is my output like being clamp and move up apart from the previous? Arghhh~! How I'm gonna fix it?
Lastly, how do i count whether my output waveform is that 120 degree? =P
Thanks...
**Hope the attachment is clear enough for you guys... =)
Audioguru
Joined Dec 20, 2007
11,248
An oscillator starts oscillating from the noise in its components being amplified.
An oscillator does not have an input signal.
The first phase-shift oscillator needs a voltage gain of about 29 or 30 from its transistor.
34,469
Here's a circuit to generate the second and third phase from a single phase signal using op amp all-pass filters. All-pass filters have a constant amplitude with frequency but can change the signal phase anywhere from 0 to plus 180° (capacitor in series) or minus 180° (capacitor to ground). The RC values to give 120° and 240° are shown for a 400Hz signal but you can adjust them for any frequency you need. For 50Hz, increase the RC time-constants by a factor of 8.
LvW
Joined Jun 13, 2013
1,760
As already mentioned: An oscillator has no signal input. It creates the signal by self-excitation.
As to the three-phase oscillator: For my opinion, a modified BUBBA oscillator (to be found via google) with three instead of four passive RC sections would be a good, simple and reliable solution.
