I have been a C++ coder for some time now, but i wanted to get into some hardware, and after taking a digital logic class in college i found the transition between code and digital components quite easy, however I still suck at analog so that is partially my problem.
My project I am working on is a 4 pin security system and i need the input from the keypad to be bounce free(for obvious reasons). I found this site and it seems to present an easy enough solution (for someone who sucks at analog circuits like me) for debouncing a push button. Unfortunately, I don't know if this circuit will work with a matrix keypad the same as it would with normal push buttons or switches, if i have to do something special, or if i am completely SOL. Thanks to replies in advanced.
Also, I have seen some posts of people suggesting pics to decode and debounce the matrix outputs automatically, but for now i am trying to get everything working using only gates, (de)multiplexers, latches, etc.. (It would kind of defeat the point to have a state machine made out of gates and latches get it's info through a microcontroller)
