All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-22-2010, 05:11 PM
guru200773 guru200773 is offline
Member
Default QUIESCENT in transistor
Can any one explain quiescent in transistor..? pls thank u
  #2
Old 05-23-2010, 01:08 AM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
Quiescent means "at rest". In a transistor circuit, the quiescent state is defined by the voltages and currents present in the circuit when the power supply is on and stable, and no signal is applied.
  #3
Old 05-23-2010, 06:47 AM
Member
Default
oh ok ok friend but how it related in Classes of amplifiers? Is there any relation between this quiescent state and load line?
  #4
Old 05-23-2010, 05:09 PM
Audioguru Audioguru is offline
Banned
Default
A class-A single transistor conducts a high current all the time. The current is modulated with the signal.
A class-B cxircuit has two usually complementary transistors (one is NPN and the other is PNP). They do not have an input bias voltage so they are completely cutoff at rest. They have crossover distortion.
A class-AB circuit usually has a complementary pair of transistors that are biased with a low quiescent currenty so they are always turned on a little with very low crossover distortion.
You can look in a text book or in Google to see a class-C and a class-D amplifier description.
  #5
Old 05-23-2010, 05:12 PM
Member
Default
ya i know this friend... but what is load line?
  #6
Old 05-23-2010, 05:32 PM
Banned
Default
You need to study the basics of electronics to know what is a load line.
  #7
Old 05-24-2010, 03:29 AM
logicman112 logicman112 is offline
Member
Default
Load line is the relationship of output voltage and current. If you consider a transistor as a two-ports network, it has input and output ports. Sometimes the relationship of output votage, means, vCE and output current means, ic, is like a line and it happens when transistor is used with resistive components not components with reactance like capacitors or inductors(Sometime those exist but they behave like short/open circuits and it is OK then).
Load line has DC and AC mathematical components and it is drawn with characteristic output diagram of transistor and true voltage and current of the transistor is on the characteristic curve and load line at the same time.
The Following User Says Thank You to logicman112 For This Useful Post:
guru200773 (05-24-2010)
  #8
Old 05-24-2010, 12:16 PM
Member
Default
thank u logic man
  #9
Old 05-25-2010, 10:27 AM
Member
Default hello
you are welcome. I will try to clarify the subject more, please ask more questions and I will try to answer. I lack time unfortunately but I wish i could review the questions. The worse is that this site does not let you review your previous posts, makes it very difficult to follow up our previous notes....
quiescent means static values. Transistor is drived by some DC voltage or current sources and some resistors. It makes you have some fixed DC voltages-currents for transistor and makes the transistor work in a specific region. Transistor has 3 basic regions to choose to work.
For small signal amplifying applications we drive it to Forward-Active-Region normally. In this region the signal AC voltage/current relations in Kierkoff's equations are linear which will lead to linear amplification.
  #10
Old 05-25-2010, 04:36 PM
Member
Default
sure dude i am a newbie so i will ask many silly question tooo
Tags
Related Site Pages
Section Title
Worksheet Design Project: intercom system
Worksheet Negative feedback opamp circuits
Worksheet BJT amplifier troubleshooting
Worksheet Design Project: Audio power amplifier
Worksheet Class A BJT amplifiers
Worksheet Bipolar transistor biasing circuits
Worksheet Bipolar junction transistors in active mode
Textbook Operational amplifier models : Operational Amplifiers
Video Lecture Amplifier Configurations - Transistors and Transistor Circuits
Textbook Biasing techniques : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Voltage Divider with a Transistor Help rachshot65 General Electronics Chat 8 02-03-2010 06:06 PM
Transistor Equation help ibigpapa General Electronics Chat 0 06-19-2009 01:23 AM
transistor driver problems popto The Projects Forum 3 06-07-2009 12:17 AM
Transistor basics azog General Electronics Chat 5 08-27-2008 02:00 AM
Stringing HV Diode and HV PNP Transistor 1o2o3o General Electronics Chat 0 05-28-2008 10:40 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
