Instrumentation Amplifier with LM324
Status
Not open for further replies.
Mangrio
Joined Nov 4, 2009
20
Will anyone help me about the Instrumentation Amplifier with LM324 IC.... I have made a circuit with this IC but it is not resulting as it to be :(
also needed help in resistor combination in above circuit.
I have made this design
t_n_k
Joined Mar 6, 2009
5,455
The LM324 probably isn't that fantastic a choice to serve as an instrumentation amplifier. It's not surprising the circuit doesn't perform as you hoped.
Posting your circuit schematic would enable a better understanding of your setup & thereby assist forum members in making suggestions for improving your circuit.
OK - see the circuit now!
t06afre
Joined May 11, 2009
5,934
Have you tried www.wikipedia.org they have some usefull info on this topic. Could tell us why it is not working and post the exact schematic for your application. Also what is the range of your input voltage
Audioguru
Joined Dec 20, 2007
11,248
Maybe your circuit doesn't work because it has no power supply.
Please show if its power supply has dual polarity and the voltage.
The LM324 works poorly above only 2kHz. It is very noisy. It has crossover distortion.
Mangrio
Joined Nov 4, 2009
20
I have applied power in orignal circuit...
Mangrio
Joined Nov 4, 2009
20
then will you please tell me that what IC i use for IA,
I have to just design a simple instrumentation amplifier (IA) for class work with any range. it just only give right the output.
will you suggest me something else plz.
t_n_k
Joined Mar 6, 2009
5,455
Try searching for "AN31 op amp collection".
Section 3 has some examples of 'practical' differential input instrumentation amp circuits. You'll note for instance that 0.1% tolerance resistors are routinely used for the critical components.
Audioguru
Joined Dec 20, 2007
11,248
Datasheets for instrumentation amplifier ICs explain why their excellent matching of opamps and resistors produces results that are much better than you can make with separate parts.
There are many high gain intstumentation amplifiers on the web made by students that are made with separate parts and they do not work!.
Maybe if yours has a low gain then it will work about as well as a piece of wire.
You still do not show a power supply for your opamps and whether it has a single polarity or a dual polarity.
You also do not show the input AC and DC voltages.
You also do not explain what is wrong with the output of your circuit.
t06afre
Joined May 11, 2009
5,934
If you look at tis document on http://www.national.com/ds/LM/LM124.pdf at page 16 you will see a schematic just like yours. You can build an Instrumentation Amplifier with your Lm324. It will not be the best one. But good enough if you want to study the principals. If you have problem with your circuit I guess something not done correct.
By NOT giving all the details we have asked for you are only wasting your own time. If you had given us the details we have asked for. Your problem would have been solved now. But this is your call.
Audioguru
Joined Dec 20, 2007
11,248
The instrumentation amplifier in the datasheet for the LM324 uses the much better and more expensive LM124A instead of the ordinary LM324N. The resistors must be well matched.
Mangrio
Joined Nov 4, 2009
20
well at last I have tried to get complete help from Wikipedia and electronics workbench...
schematic diagram on wiki
Wikipediasuggested ICs for this amplifier are these...
"Examples include AD620, MAX4194 and INA128."
I have use [AD620]
pin configuration of AD620
and its data sheet
http://www.analog.com/static/imported-files/data_sheets/AD620.pdf
now my schematic diagram on workbench according to data sheet and Wikipedia..
Function Generator & Oscilloscope setting before starts
RESULT:-
just straight line on oscilloscope.... :(
bertus
Joined Apr 5, 2008
23,001
The AD620 IS an complete instrumentation amplifier.
Take a look at page 14 of 20 of the datasheet you present.
There is a comparison between the AD620 and a homebrew instrumantation amplifier.
Bertus
Mangrio
Joined Nov 4, 2009
20
dear LM 124 and Lm 324 has same datasheet... so they can be called substitute of each other ... thats why I have used LM324 at the place of lm124.
Audioguru
Joined Dec 20, 2007
11,248
The LM124 is selected for better spec's. The LM124A is selected for the very best spec's. But it is not a good quad opamp because it is very old and it is made for low supply current.
An LM324 has very poor spec's.
Where can you buy resistors that are matched to 0.02% like the ones inside an AD620A instrumentation amplifier?
Where can you buy an LM324 that has its opamps matched as well as the opamps in an AD620A?
Why did you make a differential amplifier with three AD620 instrumentation amplifiers but did not use a resistor to set the gain of each one? Why didn't you use a single AD620A instrumentation amplifier instead?
Mangrio
Joined Nov 4, 2009
20
unfortunately i couldn't find the AD620 here in my city's shops.
Mangrio
Joined Nov 4, 2009
20
I have to just make it for my class work , whatever i.e; poor result or something it has....
please help me to design this with lm324.
JoeJester
Joined Apr 26, 2005
4,390
Mangrio,
Post a screen shot of your original non-working simulation. The original schematic has no errors and while it is not up to contemporary standards, it does work.
Status
