All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-18-2010, 05:13 AM
Grayham's Avatar
Grayham Grayham is offline
Member
Default How do I 12v to 6v (not 5v) using 7805?
I have been searching for this for a while but found nothing.
I have made the circuit from 12v to 5v using the circuit from this datasheet
http://www.amplebiz.com/spec/L7805.pdf
On page 18 (figure 19), but without the resistors R1 and R2.
But I want 6v instead of the stock 5v this regulator outputs.
I am new to electronics and cannot understand the formula for R1 and R2 to make this 6v.
Can someone please explain to me this formula:
VO = Vxx (1+R2/R1)+Id*R2
What is the 'Id' variable otherwise I might be able to work it out?
  #2
Old 05-18-2010, 07:30 AM
rjenkins rjenkins is offline
Default
Id is the chip's supply current, between positive input and it's ground or common terminal.
It's in Table 4 of the data sheet.
Unlike for a regulator that is designed to be variable, the Id current is not fully specified. The datasheet just says it will not more than 6mA, so you may have a bit of trial and error.
Try a 100 Ohm resistor between the reg common and your circuit 0V. That will need 10mA to drop the one volt you need.
Then add a 470 Ohm resistor in series with a 470 Ohm preset between the regulator output and common, that will allow you to adjust the reference current between roughly 5 and 10 mA. Together with the actual Id of the chip, you should be able to adjust the preset for 6V out.
__________________
Robert Jenkins.
  #3
Old 05-18-2010, 12:32 PM
beenthere's Avatar
beenthere beenthere is offline
Default
You can use an LM317 variable regulator or get an LM7806 in place of the 7805.
__________________
First comes the hardware, then the software.
  #4
Old 05-18-2010, 01:07 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
You can also use a similar configuration the LM317 on the 7805 to bump its voltage up. Personally I'd buy a new regulator.
If you don't understand what I'm talking about, ask.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #5
Old 05-18-2010, 02:19 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
That's close.
Id can vary due to temp, Vin and Iout.
If you figure that Id will be around 5mA +/- 5% or so, that works to get a "ballpark" output voltage with just a resistor from the GND terminal to GND, so roughly 200 Ohms per volt increase on the output, +/-10%.
However, if you use a 1K resistor from Vout to the ground terminal, then you have ID= 5mA +/-10%, plus 5mA +/- the tolerance of the regulator, which is roughly 4.8% up to around 750mA out - so you increase the precision somewhat - because the regulator's output voltage needs a 5mA load before regulation is guaranteed.
With the 1k resistor from VOUT to the GND terminal, then adding a 100 Ohm resistor to GND will give you roughly 6v out.
If any degree of precision is required, I'd go with an LM317 instead.
__________________
General info:
  #6
Old 05-18-2010, 08:24 PM
Super Moderator
Default
You could also put 1 or 2 diodes on the ground lead of the 7805, which would raise the voltage by .6 to 1.2V.
__________________
General info:
  #7
Old 05-18-2010, 08:53 PM
SgtWookie's Avatar
Expert Member
Default
A 1N4148/1N914 will have a Vf of about 0.7v @ 5mA current at room temperature.
A 1N4002 will have a Vf of about 6.5v @ 5mA current at room temp.
The trouble is that changes over temp will result in more variation than if a resistor were used; and you only have adjustments in rather coarse steps.
__________________
General info:
  #8
Old 05-19-2010, 03:48 AM
Grayham's Avatar
Member
Default
I tried that and it does work Vout is +6v
But I also tried ONLY a 200ohm resistor from common to GND and that produced the same results.
What is the different between using 2 resistors (like your example) and a single resistor just on IC's common to GND?
  #9
Old 05-19-2010, 04:44 AM
SgtWookie's Avatar
Expert Member
Default
Quote:
Assuming 1k from the OUT terminal to the GND terminal, and then 100 Ohms from the GND terminal to actual ground.
That's a very good question. I'm afraid that I cannot give you a very good answer (exception below), as the data in the datasheets does not indicate that you will receive any better result from using a single resistor from GND to ground, than using two resistors (for example, 1k and 100 Ohm vs a single 200 Ohm resistor).
The only exception is, that with a 1k resistor to the GND terminal and a 100 Ohm resistor from the GND terminal to ground, is that the minimum 5mA load is satisfied for guaranteed regulation. If your load was less than 5mA, then using the two-resistor method would be beneficial.
What the datasheet was attempting to imply is that the output voltage regulation was better than the GND terminal current regulation. Were that the case, it would be beneficial. However, the output voltage regulation is no better than the GND terminal current regulation, so it's a moot point.
Reading and interpreting datasheets can be difficult, and requires a lot of practice. If it's any consolation to you, I make my fair share of mistakes trying to read and interpret them properly.
__________________
General info:
The Following User Says Thank You to SgtWookie For This Useful Post:
Grayham (05-19-2010)
  #10
Old 05-19-2010, 07:33 AM
Grayham's Avatar
Member
Default
StgWookie thanks I will stick with the proper datasheet method of 2 resistors that being said.
Would you mind explaining (I still can't work it out) how you came up with the 1K and 100ohm resistor values?
What was your formula? (my 200ohm was just trial and error on Multisim).
Tags
Related Site Pages
Section Title
Worksheet Bipolar junction transistors as switches
Worksheet Series-parallel DC circuits
Worksheet Current divider circuits
Worksheet Voltage divider circuits
Worksheet Parallel DC circuits
Video Lecture Parallel Circuits - Circuits
Video Lecture Electrical Quantities B - Basic Electronics and Units of Measure
Textbook Simple series circuits : Series And Parallel Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
12v to 5v with 7805 tee2 General Electronics Chat 40 05-18-2010 12:38 PM
can i connect 7805 to a 12v battery? onlyvinod56 The Projects Forum 4 10-06-2009 03:02 PM
120V AC to 12V DC power supply questions slisgrinder The Projects Forum 2 05-14-2009 01:33 AM
Create 12v Lead Acid charger with 12v adapter BlackHawk9 General Electronics Chat 4 11-19-2008 06:02 PM
Learning - project pwm MrWoo The Projects Forum 5 06-19-2007 07:47 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
