All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-17-2010, 02:55 PM
boatsman boatsman is offline
Junior Member
Default Triac as a switch
I want to switch on fluorescent lamps working on 22vac 50 hz. The lamps are controlled by a time clock which switches them on every evening for about 5 hours. I need a way of switching each lamp individually but I do not want the lamp to come on automatically every day. I thought of using a latching relay with the on /off switch controlling the coil. Then I came across a circuit using a triac. I have a triac 6075 600v and 4 amps. Anode 1 is connected to one side of the lamp ( the other side to the neutral) and to the gate via a 220 Ohm resistor and a normally open press button switch. Gate 2 is connected directly to the live side of the mains. According to the book I took the circuit from it should work but for some reason it doesn't. I tried swapping between anode 1 & 2 without any result. Can anyone advise me. I don't know how to draw a circuit on this forum so I hope it's clear what I'm trying to say
  #2
Old 05-17-2010, 07:51 PM
mik3's Avatar
mik3 mik3 is offline
Default
It would be better if you can provide a circuit diagram.
  #3
Old 05-18-2010, 02:55 AM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
Are you expecting the triac to stay on after a momentary press of the switch?
What do you mean by "gate 2"? A triac has only one gate.
Ah- I'll bet you meant "anode 2".
  #4
Old 05-18-2010, 02:43 PM
Junior Member
Default Triac as switch
Sorry about mistake. I meant anode 2. The idea is that when I close the N/O switch the gate will fire and current will flow from anode 2 to anode 1 and when I release the switch the current will continue to flow between the two anodes until the time clock switches off the power and when the time clock switches the power back on there will be no current flow between the two anodes until the N/O switch is pressed again. I don't know how to draw a circuit diagram on this forum.
  #5
Old 05-18-2010, 02:57 PM
mik3's Avatar
Default
Draw the schematic with a design software and take a snapshot of the screen or draw it on paper and scan it. Then save it as png format picture and put it as an attachment.
  #6
Old 05-18-2010, 02:59 PM
retched's Avatar
retched retched is offline
Default
You have to usa a program to draw the schematic then attach the image to a post in the forum.
LTSpice is a free schematic capture program and simulator.
click 'Go Advanced' while posting and under your text box you will see 'Manage Attachments' box. You can upload images and attachments there.
using the button that looks like a mountain view with a sun in the background:
Will add the images to the post after they have been uploaded via the 'Manage Attachments' options.
Link to LTSpice page:
http://www.linear.com/designtools/software/#Spice
__________________
-rm-
  #7
Old 05-18-2010, 03:48 PM
Ron H's Avatar
E-book Developer
Default
Quote:
The triac will turn off whenever the current goes to zero, which is once every half cycle.
http://en.wikipedia.org/wiki/TRIAC
  #8
Old 05-19-2010, 06:25 PM
Junior Member
The circuit I have been using is the one shown in vol 3 semiconductors chapter 7 using the triac and is the circuit without the capacitor. I used a 200 ohm resistor instead of the potentiometer and I tried both ways anode 1 and anode 2. The triac I am using is 6075 rated at 4 amps and 600 volt. No results either way. Any advice would be appreciated.
  #9
Old 05-19-2010, 06:51 PM
mik3's Avatar
Default
Is your supply voltage 22V AC or 220V AC?
If it is 220V AC then it is probably fried.
  #10
Old 05-19-2010, 06:54 PM
mik3's Avatar
Default
If it is 220V AC then it is probably fried with a 200 ohm gate resistor.
Tags
Related Site Pages
Section Title
Worksheet Latch circuits
Worksheet CMOS logic gates
Worksheet Thyristors
Worksheet Thyristor application circuits
Textbook The Silicon-Controlled Switch (SCS) : Thyristors
Textbook The TRIAC : Thyristors
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook Basic gate function : Digital Integrated Circuits
Textbook Digital logic functions : Ladder Logic
Textbook Thyristors : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
triac switch fisho The Projects Forum 2 11-28-2009 12:09 AM
JFET audio switch question dfro General Electronics Chat 10 10-07-2009 04:22 PM
Question regarding a 12v DPDT switch loydt General Electronics Chat 10 03-03-2009 10:25 PM
voltage tests and thermostats ac circuits bonkers General Electronics Chat 4 12-14-2008 12:41 PM
Switch box for channel switching modification of guitar amp aj7877 The Projects Forum 2 07-05-2008 10:59 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
