transformer issues- no voltage on DC side
100Dave
Joined May 4, 2010
6
Hello I am building the 12AX7 vacuum tube amplifier, but I have run into some problems with the power supply. I purchased 3 of the transformers listed in the parts list, and have built the circuit as shown in the article ( I think ). I never seem to get the correct voltage on the other side of the transformer(s) ( I tried all three of them) I actually dont get ANY measurable DC voltage and I thought I would see 170 VDC.
I am connecting my 12V power supply leads to the yellow wires on the DC side of the transformer ( 6.3V x 2 ) and checking the other side for voltage....nothing.
Also, I have tested the transformer in the tradional way and hooked up the AC leads to wall voltage and read corrrect DC voltage ( 12V ) off of the DC side, so I at least kindof understand transformers , right?
Can someone give me some pointers or tests I can do to eliminate this issue or component?
thanks
Dave
SgtWookie
Joined Jul 17, 2007
22,230
It would help a great deal if you would post the schematic, parts list, and information about the particular transformers you purchased.
The 12 part in the 12AX7 means they use 12v for the heaters.
100Dave
Joined May 4, 2010
6
hello all thanks for the quick replies, it turns out that I was applying 12VDC from my newly purchased power supply into a 12 VAC transformer and expecting things to work. I re-read the instructions and I am now getting the expected voltages.
thanks all
Dave
