All About Circuits Forum
Go Back   All About Circuits Forum > Circuits and Projects > The Completed Projects Collection
Notices
The Completed Projects Collection A collection of completed projects from All About Circuits forum members. Comment, ask questions, and add to their ideas.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-24-2010, 10:06 PM
cumesoftware's Avatar
cumesoftware cumesoftware is offline
Default Project: "Cygnus" 2-way speakers
List of components:
C1/3 Capacitor Visaton ELKO spez. 2,2F;
C2 Capacitor Visaton ELKO spez. 10F;
FTE1 Woofer Visaton SC 13 8 OHM;
FTE2 Tweeter Visaton SC 10 N 8 OHM;
L1 Coil Visaton SP 0,68mH 1mm;
L2 Coil Visaton SP 0,68mH 0,6mm;
R1 8,2Ω wirewound resistor (5% tol., 5W).
R2 2,2Ω wirewound resistor (5% tol., 7W).
R3 18Ω wirewound resistor (5% tol., 5W).
Electrical parameters:
- Pnom = 50W
- Ppk = 80W
- R = 6,4Ohm
- Znom = 8Ohm
Audio characteristics:
- Frequency response (-10dB): 40-20000Hz
- Sensitivity (1W/1m): 87dB
Recommended enclosure specifications:
- Type: Ported (3th order quasi-Butterworth alignment)
- Volume: 9.756L
- Recommended duct: Monacor BR-30HP (length: 64mm)
- Resonant frequency (Fb): 50.64Hz
- -3dB frequency (F3): 52.30hz
__________________
I love the smell of toasted transistors in the morning.
Last edited by bertus; 10-05-2010 at 09:18 PM. Reason: PCB diagram uploaded , changed title.
  #2
Old 04-27-2010, 06:05 PM
bertus's Avatar
bertus bertus is offline
Administrator
Default
Are you also going to make a description of the housing for the speakers?
That would make it a complete project with your filter set you made now.
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #3
Old 04-27-2010, 06:46 PM
R!f@@'s Avatar
R!f@@ R!f@@ is offline
Send a message via MSN to R!f@@
Thumbs down
I wouldn't use passive cross over ever.
active cross over is the way to true audio.
By the way, ever thought about using wire wound resistors introducing extra inductance in to the crossover, you should go for cement ones.
Or am I wrong here?
__________________
R!f@@
Do not get angry and do not be harsh because you will never regret being kind
  #4
Old 04-27-2010, 09:33 PM
Default
Quote:
Originally Posted by bertus View Post
Greetings,
Bertus
Thanks! The box is already planned and I'll post it any time soon.
Or am I wrong here?
Indeed! Active crossovers are much more linear, but they require separate output stages for the high and low frequencies. You can have two approaches: an amplifier having those stages or an active speaker.
About the resistors, the ones I'm using have a cement filler. And the inductance is very, very small.
__________________
  #5
Old 04-28-2010, 03:25 PM
R!f@@'s Avatar
Default
Indeed
I guess then It's OK
__________________
R!f@@
  #6
Old 05-18-2010, 04:51 PM
abdus abdus is offline
Junior Member
Default
Quote:
Originally Posted by cumesoftware View Post
List of components:
- Pnom = 50W
- Ppk = 80W
- R = 6,4Ohm
- Znom = 8Ohm
- Type: Ported (4th order quasi-Butterworth alignment)
- Volume: 9.756L
- Resonant frequency (Fb): 50.644Hz
hello there ,
can i use this circuit with the bass trrible and midi controller??
i jst have made the passive low pass bass trreble and midi circuit with adjustable gain of +-18db an i use tda7052 to amplify the power with 8 ohms speaker
can i use this circuit with that one???
  #7
Old 05-22-2010, 08:59 PM
Default
Quote:
Originally Posted by abdus View Post
hello there ,
If I understood your question, I think you will have no problem using those speakers with your amplifier. These are 8Ohm speakers.
__________________
  #8
Old 05-26-2010, 12:53 AM
Audioguru Audioguru is offline
Banned
Default
I use tda7052 to amplify the power with 8 ohms speaker
If the supply is 6V then the output at clipping into 8 ohms is only 0.96W. A cheap clock radio has more power.
Your tone controls have a max boost of about 80 times the power so unboosted frequencies have a max power of only 0.012W.
  #9
Old 05-26-2010, 09:44 AM
Default
Quote:
Indeed! Those speakers will sustain up to 50W nominal power, which is far greater than the power of 1W that a TDA7052 can provide.
I'm afraid we are going off-topic here. I don't see any point or relation with the actual project being discussed here.
__________________
  #10
Old 10-05-2010, 09:10 PM
Default
Someone messed this up big time. This thread should be called "Project: "Cygnus" 2-way speakers". This is Cygnus, not Lynx.
__________________
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Project: "Unus" multimedia active speakers cumesoftware The Completed Projects Collection 6 02-13-2010 11:55 PM
Project: "Quatour" multimedia active speakers cumesoftware The Completed Projects Collection 26 02-12-2010 01:35 PM
Project: Portable active speakers (2 X 0.3W) cumesoftware The Completed Projects Collection 8 09-26-2008 07:54 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
