All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-22-2010, 09:41 AM
nikomas nikomas is offline
Junior Member
Default Constant current source with transistor and op amp
hi everybody,
can someone explain to me how work constant current source with pnp transistor and op amp like is shown here
http://basicelectronic.blogspot.com/...e-circuit.html
thank you for answering
  #2
Old 04-22-2010, 10:58 AM
Markd77's Avatar
Markd77 Markd77 is offline
Default
The op amp is comparing the voltage across the resistor R to the voltage reference and keeping them the same by making the transistor conduct more or less.
The voltage across R is proportional to the current.
The unlabelled resistor is the load and it's resistance can be varied without the current through it changing.
  #3
Old 04-22-2010, 11:05 AM
t_n_k t_n_k is offline
Default
Firstly - there is a small error in the schematic. The feedback from the transistor emitter should go to the OP-AMP negative terminal and the reference input should go to the positive input terminal.
Does that correction provide any further help in understanding the circuit operation?
  #4
Old 04-22-2010, 07:38 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Quote:
Originally Posted by Alberto View Post
You will be better off using an adjustble voltage regulator (LM317 or LM338)
wired as constant current supplier. ( see the regulator data sheet)
An LM317 might be easier if they require current in a range of 10mA to 1.5A.
However, if they need less than 10mA, they will either need to go to an LM317L which is rated for as low as 5mA, or use two regulators; one sourcing >= 10mA, and the other sinking >= 10mA. The current difference between the two can then be as low as zero.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #5
Old 04-22-2010, 08:39 PM
Junior Member
Default
can you explain with more details? why is constant current Ie=Vref/R? and why feedback from the transistor emitter should go to the OP-AMP negative terminal?
  #6
Old 04-22-2010, 09:52 PM
bitrex bitrex is offline
Member
Default
Quote:
An op-amp always "fights" to keep its inputs at approximately the same voltage, when connected as a negative feedback amplifier - that is with the output connected in some fashion to the inverting or "-" input. Consider the equation for a differential amplifier, which an op-amp is:
 V_o = A(V_+ - V_-)
Where V_o is the output voltage, A is the op amp open loop gain, V_+ is the noninverting input voltage, and V_- is the inverting voltage.
If you connect V_o directly to V_-, that is  V_o = V_- , you get the following equations:
 V_- = A(V_+ - V_-)
 V_-(1 + A) = A*V_+
  V_- = \frac{V_+}{\frac{1}{A} +1}
Most op-amps have extremely high open loop gain A at low frequencies...maybe 1 million. So the 1/A term becomes very close to 0, and you get approximately
 V_- = V_+ .
In the constant current source circuit, since the two input voltages to the op amp are trying to be equal, you can analyze it by assuming this condition is true. You then see that the voltage at I_e, which should be the negative input in the schematic must be the same as the reference voltage, and the op-amp output will supply an output voltage about 0.6 volts lower to make this true: the op amp automatically compensates for the voltage rise across the transistor. The emitter current will then be the voltage drop across the emitter resistor, which is Vref/R, and the collector will be the same times the factor alpha.
The Following User Says Thank You to bitrex For This Useful Post:
nikomas (04-23-2010)
  #7
Old 04-23-2010, 12:55 PM
Junior Member
Default
Alberto
thank you for answering.
I need to have constant current of 35mA through pt100 thin film resistor. That current will heat pt100 and it will have resistance of 135ohms. If i understand good i set that current with choosing resistor R=1.25V/35mA? what input voltage i need? Vin = 35mA*135ohm + 3V (Vdrop)?
  #8
Old 04-27-2010, 09:26 PM
Darren Holdstock Darren Holdstock is offline
Default
It doesn't help in understanding this circuit in that it's all upside-down because of the ground-referenced load and PNP transistor. You'll need to think of Vcc as being your reference point, not ground. Just like in the old days when the only transistors available were germanium PNP devices, and cars had positive earths.
The voltage across the sense resistor R will be Vref. Simple as that. But here's something I found out the hard way - don't make the sense resistor too large, or the feedback will form a pole with the op-amps parasitic input capacitance, and you'll have gain peaking and/or instability. As a rough rule of thumb, below 100 ohms is good; lower than that is even better. If the sense resistor comes out in the calculations as larger than this then lower the input reference with a lower voltage Vref or a couple of resistors in a potdown arrangement.
The op-amp inputs appear backwards because the PNP signal inverts the signal to the feedback, so as it's already inverted this has to go to the non-inverting input.
  #9
Old 04-28-2010, 08:53 AM
Member
Default
I'm pretty sure it won't work the way it's set up in the schematic. The PNP isn't inverting anything - if the voltage from the op amp goes up or down the signal will appear in phase at the emitter (like an emitter follower) and appear in phase at the "+" input: positive feedback instead of negative. Imagine changing the transistor from PNP to NPN and swapping ground and the supply - still wouldn't work!
  #10
Old 04-28-2010, 07:21 PM
Norfindel's Avatar
Norfindel Norfindel is offline
Default
mmm... Assuming it's at equilibrium, if Iout rises, more voltage drops in R, so the voltage at the emitter of the transistor (AMP+) lowers, lowering the output of the amplifier, which causes still more current to flow. Yeah, it seems like the amplifier inputs are reversed.
Correctly done, with negative feedback, the amplifier's inputs are going to be at the same voltage (this is the key to understanding opamp circuits with negative feedback). If AMP+ is at Vcc-Ref, then AMP- is going to be kept at the same level, which is the same that the bottom of R. The voltage drop over R is then going to be = to Vcc - (Vcc - Vref) = Vcc - Vcc + Vref = Vref. If the voltage drop in R is fixed, the current is fixed.
If for any reason the current raises (for example: transistor heating), the voltage drop in R will be more, AMP- will lower, AMPout will rise, and the transistor is going to conduct less current, regulating it
Tags
Related Site Pages
Section Title
Worksheet Class A BJT amplifiers
Textbook Divided feedback : Operational Amplifiers
Video Lecture Op Amps Characteristics (Part 2) - Internal Circuitry - Op Amps and Op Amp Circuits
Textbook Class B audio amplifier : Analog Integrated Circuits
Textbook Current mirrors : Bipolar Junction Transistors
Textbook Feedback : Bipolar Junction Transistors
Textbook Biasing calculations : Bipolar Junction Transistors
Textbook The common-collector amplifier : Bipolar Junction Transistors
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Textbook Simple op-amp : Discrete Semiconductor Circuits
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
