All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Embedded Systems and Microcontrollers
Notices
Embedded Systems and Microcontrollers Discussion forum for projects and working with embedded systems and microcontrollers (FPGAs, PICs, AVRs). Get help with hardware issues and embedded programming.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-22-2010, 02:40 AM
kasula4 kasula4 is offline
Default PIC32 Multiple interrupts issue
I am trying to use multiple interrupts in PIC32 microcontroller. When I use 2 interrupts lets say UART and 1 timer the microcontroller is working fine but when I use UART and 2 timer interrupts the microcontroller freezes. I have the following code in the interrupts.
#include "Tao4ch_defs.h"
// UART 2 interrupt handler
// it is set at priority level 2
void __ISR(_UART_2A_VECTOR, ipl3) _U2ARXInterrupt(void)
{ char ch;
IFS1bits.U2ARXIF = 0; // Reset the RX interrupt flag.
ch = U2ARXREG;
Char_in = ch;
Char_cap = 1; // Flag to indicate a character has been received.
// 0x0A is a line feed. Some terms attach linefeeds so must discard them.
if (ch != 0x0D && ch != 0x0A) { // If the rx'd char is not 'enter' or lf
Rx_buff [Rx_index] = ch; // load the rx buffer with the char and
Rx_index++; // increment the index.
if (Rx_index >= RX_BUF_LEN)
Rx_index = 0;
if (ch == 13) { // When the 'enter' char is received
Rx_buff[Rx_index] = 0; // put a null char in the string.
Rx_index = 0; // and reset the index.
Com_flag = 1; // Com flag should be reset after the
} // buffer has been read.
// string is processed.
// interrput code for the timer 1
void __ISR( _TIMER_1_VECTOR, ipl2) _T1Interrupt( void)
int i;
asm("ei"); //To enable interrupts
// clear interrupt flag and exit
IFS0bits.T1IF = 0;
sampleBuffer[sampleIndex].re = read_ext_adc1(5) - 25485; // read the ADC into the real part of the samplebuffer
// increment the sampleIndex
if (sampleIndex == (N-1))
sampleIndex = 0;
else
sampleIndex++;
} // T3 Interrupt
void __ISR( _TIMER_3_VECTOR, ipl1) _T3Interrupt( void)
{ asm("ei");
IFS0bits.T3IF = 0;
//do something
  #2
Old 04-22-2010, 09:18 AM
rjenkins rjenkins is offline
Default
Try to avoid doing any complex processing within an interrupt, keep it short so you do not have to re-enable interrupts while one is active.
Another speed-up is to make buffers power-of-two lengths and simply do
rx_index++;
rx_index &= 0x1f; to limit the index to 0-31 or whatever.
I usually poll any i/o within a timer routine, cycling fast enough to ensure no overruns.
I'd generally run it at about 10KHz, but I have used in excess of 250KHz on PIC16.
Examples, comments added for info:
Code:
// Storage declarations
int     cd_tbuf[32]; // The data buffer
int     cd_tbufi; // Buffer Input pointer
int     cd_tbufo; // Buffer Output pointer
int     cd_tbufc; // Buffer Count
// Initialisation
void rs_clear(void) {
    rs_tbufi = 0;
    rs_tbufo = 0;
    rs_tbufc = 0;
// Routine to buffer TX characters
void rs_tput(int i) {
    rs_tbuf[rs_tbufi++] = i; // Store data, inc pointer
    rs_tbufc++; // Inc buffer count
    rs_tbufi &= 0x1f;  // Pointer roll-over to zero.
// TX poll routine called from within RTC interrupt
void rs_send(void) {
// If nothing to send, quit.
    if(rs_tbufi == rs_tbufo) {
        rs_tbufc = 0;
        return;
// Otherwise, if UART is not busy,
    if(rs_tx_rdy())    {
        putchar(rs_tbuf[rs_tbufo++]); // Send character & inc pointe
        rs_tbufo &= 0x1f; // Roll-over
        rs_tbufc--; // Dec buffer count
Select All
(Note - naming - That's pulled out of a program that has multiple comms routines named with different prefixes, that particular one just happened to be rs_... ).
__________________
Robert Jenkins.
  #3
Old 04-22-2010, 12:41 PM
BMorse's Avatar
BMorse BMorse is offline
Default
Do you have Multi vector Interrupts Enabled??
here is a code snippet I used with the Pic32 interrupts.....
at the bottom of the code, you can see my Interrupt initialization routine where I enable the Multi vector interrupts..... and as RJenkins had said, try not to do too much in an interrupt routine, You could very well miss a different interrupt....
Code:
// Interrupts
#ifndef _bINT_HEADER_FILE
#define _bINT_HEADER_FILE
void __ISR( _RTCC_VECTOR,ipl1) RTCCInterrupt( void)
    MODE_CHANGED=1;
    RtccAlarmDisable();
    SYS_MODE++;                //Increment SYS_MODE to reflect current state of system
    mRTCCClearIntFlag();    //Clear Interrupt Flag
}//RTCC Interrupt
void __ISR(_UART1_VECTOR,ipl2) IntUart1Handler(void)
    //is this an RX interrupt??
    if (mU1RXGetIntFlag())
    {//clear the RX interrupt flag
        mU1RXClearIntFlag();
        //putcUART2(ReadUART1();
    }//RX Interrupt
    if (mU1TXGetIntFlag())
    {//we dont care for it so just clear it
        mU1TXClearIntFlag();
    }//End TX Interrupt
void __ISR( _EXTERNAL_2_VECTOR,ipl3) INT2InterruptHandler(void)    //PIR Sensor Interrupt
    //mPORTDToggleBits(BIT_0);
    asm ("ei");
        Motion=1;            //Set Flag
        Vanity_On=1;        //Set Flag
        mSSR1_ON();            //Turn On Vanity Light
        LOD=0;                //Reset Light On Delay
        mINT2ClearIntFlag();
}//End INT2
void __ISR( _EXTERNAL_1_VECTOR,ipl5) INT1InterruptHandler(void)    //MPR084Q Interrupt Source,
        //Not used right now, using polling method instead
    asm ("ei");
    mINT1ClearIntFlag();
}//End INT1
#endif
Init_Interrupts()
    mRTCCSetIntPriority(1);                //Set Real Time Clock And Calendar Priority Level
    mRTCCClearIntFlag();                //Clear RTCC Interrupt Flag
    mINT2SetIntPriority(3);                //Set Interrupt Priority for External Int Source 0
    mINT1SetIntPriority(5);                //Set Interrupt Priority for External Int Source 1
    INTEnableSystemMultiVectoredInt();        //Enable Multi vectored Interrupts
    mINT2IntEnable(1);                //Enable External Interrupt 0
    mINT1IntEnable(1);                //Enable External Interrupt 1
}//End Init Interrupts
Select All
P.S.
I also noticed when I was working with the Pic32, that you have to start with the lowest priority first..... if you notice in my code ipl1 is the first routine, all the way down to ipl5....
B. Morse
__________________
There is no spoon -Neo-
Disclaimer: The example programs,circuits, projects and information I provide or post on this web site are for educational purposes only. By copying anything from this site posted by me, you agree to the "as is" nature of the programs, circuits, information and to the statements listed in this disclaimer.No warranty or liability is expressed or implied. Working with AC /DC voltages can be dangerous and even deadly. Proceed at your own risk!
  #4
Old 04-22-2010, 01:30 PM
Default
Thanks for the replies. I have a question for BMORSE. I think IPL7 is the highest priority so I think asm(ei) should be used in lower priorities IPL(0) etc.., were you able to run the same code successfully.
  #5
Old 04-22-2010, 01:52 PM
BMorse's Avatar
Default
Quote:
You are right ipl7 is the highest priority level, I used the asm (ei), just to make sure other interrupts are still enabled when entering that ISR.....
And yes, the way I have the ISR's set up, seems to work very well for me....
B. Morse
__________________
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Usb issue aliashar86 General Electronics Chat 2 02-09-2010 03:06 PM
nested interrupts in 8051 helpppp!!!!! qrious Embedded Systems and Microcontrollers 6 02-08-2010 01:14 PM
A small hitch in my ultrasonic receiver. I don't know if its a H/W or S/W issue. kris_maher Embedded Systems and Microcontrollers 14 09-17-2009 02:17 AM
pic16f84 two interrupts at once krvavizmaj Embedded Systems and Microcontrollers 3 01-27-2008 04:56 PM
how to write program interrupts or design interrupts. cholriak Programmer's Corner 1 09-13-2006 08:44 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
