All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-21-2010, 12:46 PM
hazim hazim is offline
Default Touch on/off switch circuit
I'm trying to make a touch on/off switch circuit with one plate; i.e. when I touch the plate it switches on, when I touch it again then it switches off. I built the attached circuit for a friend from several months, it worked fine with 12V power source, but with 9V or less it didn't. I want to use the circuit with 5V source, so I tried to increase the 10M resistor but it didn't worked. I think with 12V the current through the 10M resistor and the human body to the earth decreases the voltage on pin 2 and triggers the IC.. with 5V the 555 triggers only if I touched the ground (0V) with my second hand at the same time I touch the plate.
Anyway, my aim is to turn a circuit on and off by touching a plate as I described. You my suggest another way, other than the attached circuit if it consents my purpose. Any ideas are appreciated.
Thanks,
Hazim
  #2
Old 04-21-2010, 01:19 PM
Bosparra Bosparra is offline
Member
Default
Have you tried lowering the value of the 10M? With the decreased voltage comes decreased current for the same resistor value.
  #3
Old 04-21-2010, 01:29 PM
rjenkins rjenkins is offline
Default
That circuit requires contact with the sensor to pull the trigger input below it's operating threshold.
It won't be reliable with a single contact, it requires definite earth (0V) contact (albeit via a high resistance) to operate.
You would be better off with a capacitive style switch that does not rely on a dc circuit.
Example of a 5V one here:
http://www.discovercircuits.com/DJ-Circuits/5vmom1.htm
__________________
Robert Jenkins.
  #4
Old 04-21-2010, 01:39 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
How about this circuit?
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #5
Old 04-21-2010, 02:29 PM
Default
Yes I tried lowering the value of 10M, as I expected, it went from bad to worse. A capacitive style switch should work fine, but the circuit will be bigger and more complex, I think I can find a simpler way using a timer or maybe an op-amp/comparator.
The circuit Bill provided seems to be ok, but it uses a momentary push button switch instead of a touch contact
  #6
Old 04-21-2010, 02:34 PM
kingdano kingdano is offline
Default
perhaps you could try his circuit using your touch-contact switch - and see if it works?
  #7
Old 04-21-2010, 05:32 PM
Default
kingdano, the touch-contact switch isn't working properly.
  #8
Old 04-22-2010, 05:47 AM
John P John P is offline
Default
I think the right way to do this is to use an oscillator where the frequency depends on the value of a small capacitor connected to ground. Touch the wire connected to the capacitor, and you'll add your own capacitance in parallel with the existing cap, and it'll change the oscillator frequency, which can be detected and used to switch the circuit. But I can't deny that it's a step up in complication.
Wikipedia says:
"The Human Body Model for capacitance, as defined by the Electrostatic Discharge Association (ESDA) is a 100pF capacitor in series with a 1.5kΏ resistor."
The Following User Says Thank You to John P For This Useful Post:
hazim (04-22-2010)
  #9
Old 04-22-2010, 06:37 AM
Default
The simple capacitive touch switches use an oscillator fed via a high resistance to the touch plate.
The touch plate also connects to a simple rectifier / comparator.
When the plate is touched, the level of the AC signal is reduced due to body capacitance.
__________________
Robert Jenkins.
The Following User Says Thank You to rjenkins For This Useful Post:
hazim (04-22-2010)
  #10
Old 04-22-2010, 03:49 PM
Default
OK, there you go. Use an oscillator. I don't think you need a rectifier exactly, more like a pulse and filter arrangement, where each cycle puts a bit of charge on a capacitor, and it drains off through a resistor. The faster the pulses come in, the higher the voltage will go, and then you use a comparator to test it.
Tags
Related Site Pages
Section Title
Video Lecture Capacitors (Part 1) - Inductors,Capacitors,Transformers
Textbook Shock current path : Electrical Safety
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Textbook Electric fields and capacitance : Capacitors
Similar Threads
Thread Thread Starter Forum Replies Last Post
switch box help?? 3xstereo in, 3x on/off switches & 1xstereo out Fingers The Projects Forum 2 02-02-2010 10:50 PM
Simple Audio Switch Circuit - Help Needed Aldanor The Projects Forum 4 04-20-2009 12:48 PM
dual circuit switch help Section8 The Projects Forum 1 04-12-2009 01:24 AM
voltage tests and thermostats ac circuits bonkers General Electronics Chat 4 12-14-2008 12:41 PM
capacitor discharge voltage help Sean Reed Homework Help 16 03-01-2008 05:19 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
