Good day folks,how do i identify the base,collector and emitter pins of a transistor.
Thread Starter Ngene Joined Apr 9, 2010 3 Apr 20, 2010 #1 Good day folks,how do i identify the base,collector and emitter pins of a transistor.
bertus Joined Apr 5, 2008 22,277 Apr 20, 2010 #2 Hello, Take a look at this page of the eBook: http://www.allaboutcircuits.com/vol_3/chpt_4/3.html Bertus
C CoolBeer Joined Mar 29, 2010 40 Apr 20, 2010 #3 If available the datasheet is a good source for that information.
S sameer09-ee-14 Joined Apr 18, 2010 1 Apr 20, 2010 #4 place the transistor on your palm with plane surface towards you then the left most lead will be base the middle will be the collector and the right one will be the emitter,for a japanesse standard bjt.
Thread Starter Ngene Joined Apr 9, 2010 3 Apr 20, 2010 #5 Thank you so much,i've been trying to figure out this for weeks.Thanks,you're great.
Thread Starter Ngene Joined Apr 9, 2010 3 Apr 20, 2010 #6 Great thanks to you Super moderator,you're really super.Thanks,for the link.
