All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-17-2010, 01:57 PM
Mazaag Mazaag is offline
Default Common Mode Gain of Diff Amplifier
Hi Guys,
Could someone please explain to me why we consider the common mode signal going into a differential amplifier (when wanting to calculate the common mode gain) is equal to the average of the inverting and non-inverting signals? I understand what common mode gain is but don't understand why the average is the common mode signal..
Thanks guys!
  #2
Old 04-18-2010, 12:52 AM
beenthere's Avatar
beenthere beenthere is offline
Default
That isn't correct. A common mode signal is equally present on both inputs. A difference amplifier will not respond to a common mode signal (no difference on either input).
http://www.edn.com/article/CA289961.html
__________________
First comes the hardware, then the software.
  #3
Old 04-18-2010, 02:40 AM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
That is true if the amplifier is ideal.
  #4
Old 04-18-2010, 04:49 AM
The Electrician The Electrician is offline
Default
The very first paragraph of the article you referenced says that it is correct:
"A common-mode voltage is one-half the vector sum of the voltages between each conductor of a balanced circuit and the local ground."
  #5
Old 04-18-2010, 05:24 AM
Default
Quote:
Originally Posted by Mazaag View Post
Hi Guys,
Thanks guys!
Imagine that we construct signals to be applied to the inputs of a differential amplifier.
Let Vc be a common mode signal. This signal will be applied to both inputs.
Let Vd and -Vd be differential signals applied to the inputs.
To one input we apply Vc + Vd and to the other we apply Vc + (-Vd)
The differential signal seen by the amplifier is the difference between these two, namely (Vc + Vd) - (Vc - Vd) = 2Vd
Let's take the average of the two input signals:
((Vc + Vd) + (Vc - Vd))/2 = (2Vc)/2 = Vc
We have recovered the common mode signal.
  #6
Old 04-18-2010, 02:02 PM
beenthere's Avatar
Default
Taking the case of an instrumentation amplifier and applying a resistive bridge (let's say strain gauges) to the inputs. With the bridge balanced and 10 volts applied as the excitation voltage, the common mode voltage is 5 volts. That is, + 5 volts present on the inverting and non-inverting inputs.
The output of the IA is not 5 volts, but 0 volts. The classical three op amp IA appears to be a buffered difference amplifier.
__________________
Tags
Related Site Pages
Section Title
Worksheet Differential transistor amplifiers
Worksheet Linear computational circuitry
Worksheet Summer and subtractor opamp circuits
Worksheet Class A BJT amplifiers
Textbook Practical considerations : Operational Amplifiers
Textbook Averager and summer circuits : Operational Amplifiers
Textbook Negative feedback : Operational Amplifiers
Textbook Feedback : Bipolar Junction Transistors
Textbook The common-collector amplifier : Bipolar Junction Transistors
Textbook Differential amplifier : Discrete Semiconductor Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Amplifier Design Problem (High gain, high BW) Schniz2 Homework Help 0 04-15-2010 07:41 AM
Understanding interrupt on port state change ke5nnt Embedded Systems and Microcontrollers 12 01-31-2010 03:12 PM
Does an amplifier have a max gain ? simeonz11 The Projects Forum 4 01-09-2010 12:50 PM
Common Emitter for audio amplifier Ryouko Homework Help 5 04-27-2009 08:41 PM
Common Mode Output/OpAmp zbst Homework Help 2 03-25-2008 12:10 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
