Hi. This is my first post here. I am somewhat of a newbie with electronics. Well, I am working on a project, and I want to build a circuit to reverse the direction of a dc motor. Here is what I want to do...
The dc motor will be driving a pulley that moves an object on a fixed track. On both ends of the track there will be a switch (of sorts) that when engaged will reverse the direction of the motor, so that the object on the track will constantly be moving back and forth on the track, from one end to the other.
So, my question is about the circuit itself. Could I use a bistable multivibrator to achieve this? And, if I could, how would I wire the motor to the outputs to achieve this reversal? I am not opposed to the idea of using any other circuit, so any suggestions on how to achieve the change in direction would be great.
Thank you.
Thank you.
