All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-14-2010, 12:43 PM
Management Management is offline
Default AC riding on DC
Please throw out your random thoughts on this please. Help me get my brain spinning.
Some technologies out there use AC riding on DC for digital communications. One example is in the 4-20mA space where HART is a communications protocol that uses two frequencies for 1s and 0s coupled to the DC 4-20mA.
There is also techs coupling high frequencies on AC power.
If I wanted to couple high frequency content onto 100V DC what issues would I run into, granted I have the components that can do the coupling. How strong a AC would have to be and what would happen if it were even higher DC voltage.
Thanks.
  #2
Old 04-14-2010, 01:56 PM
rjenkins rjenkins is offline
Default
There are two basic methods.
One is a transformer with the secondary in series with a couple of small value high voltage capacitors, connected across the main supply.
The other is a current transformer operating in reverse, so you have a turn or two or the power cable and some hundreds of turns of signal-side cable.
With both types, the isolated (signal) side can be tuned to the carrier frequency.
The first type (voltage feed) is better when the power side has a reasonable impedance at the carrier frequency, like with X-10 automation gear and the AC main power circuit.
The second (current drive) works when one end of the circuit has low impedance at high frequencies, giving a return path for the current modulation.
You can also include chokes or filters to isolate the part of the system with the carrier signal from the power source and load, so the carrier is not shorted.
__________________
Robert Jenkins.
  #3
R!f@@'s Avatar
R!f@@ R!f@@ is offline
Send a message via MSN to R!f@@
Default
U should talk about modulation than a ripple on a DCV
__________________
R!f@@
Do not get angry and do not be harsh because you will never regret being kind
  #4
Old 04-15-2010, 01:03 PM
Default
Thank you for such a detailed response.
So which is considered safer? "Current Drive"?
In regards to the impedance usually the lines are unterminated and run for short and long distances so the impedance can be all over the place. If the cable used for DC was always fixed and then isolated from the source then I could imagine that the impedance would also be pretty much fixed. Especially with the coupling occurring after the isolating choke/filter.
Lets assume the carrier frequencies are in the CENELEC Band (kHz) and another method in the tens of MHz. What would the impedance of the power side be (assuming isolated) to use the first method (transform + cap. couple)?
  #5
Old 04-15-2010, 01:04 PM
Default
Quote:
Your right but I attempted to keep it simple.
Modulation using OFDM in the above two bands. Trying to brainstorm about issues and requirements that I would run into doing this on high voltage DC lines.
  #6
Old 04-17-2010, 09:51 AM
retched's Avatar
retched retched is offline
Default
I have not looked into the technology yet, but there is an interest in IP over HV. Which is IP on high voltage AC lines.. I suppose you could also couple AC to hv DC lines to do the same, however, the deterioration of the DC signal is greater over the same distance (long distance) as AC. I dont know if you would have to sync the signals, or just seperate them regardless of AC freq. and DC freq.
__________________
-rm-
Tags
Related Site Pages
Section Title
Video Lecture Transformers (Part 1) - Inductors,Capacitors,Transformers
Worksheet Signal modulation
Worksheet Step-up, step-down, and isolation transformers
Worksheet Passive filter circuits
Textbook Electrical isolation : Transformers
Textbook Resonant filters : Filters
Textbook Special transformers and applications : Transformers
Textbook Electrical signal types : Digital Communication
Textbook Input and output coupling : Bipolar Junction Transistors
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
AC OR DC ? Servo help GARYN General Electronics Chat 10 03-03-2014 05:02 PM
Phone lines??? AC or DC problem Mathematics! General Electronics Chat 16 02-16-2011 01:07 PM
dc to ac inverter keithg General Electronics Chat 4 06-02-2009 12:33 AM
120V AC to 12V DC power supply questions slisgrinder The Projects Forum 2 05-14-2009 01:33 AM
Differences between AC / DC Motors. cjdelphi General Electronics Chat 3 05-01-2009 03:58 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
