All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-08-2010, 04:22 PM
roltex_rohit123 roltex_rohit123 is offline
Member
Default testing transistors and capacitors.
how can i test a transistor like hsd965, a power mosfet like IRF9z34 and general NPN and PNP transistor with my multimeter? also i wanted to know how to test capacitors.
  #2
Old 04-08-2010, 05:09 PM
beenthere's Avatar
beenthere beenthere is offline
Default
For transistors, a diode check function is most handy. Most meters have that included.
In general, you should see a PN junction Base to Emitter, and Base to Collector. Unless the transistor is germanium, there should not be any conduction Emitter to Collector in any polarity.
For FET's, there is the inherent Drain to Source diode, which is in opposition to the polarity of the device. If you can read that PN junction, and all other terminals show open, the FET is probably good. What is handy is that they nearly fail short, whereas transistors can go open or short.
Capacitors other than electrolytic don't fail without changing color or showing obvious signs. Electrolytics often show swollen cases, split vents, or do explode. If your capacitor is in one piece, it will be within the stated tolerance. We are done with the old wax and foil and silver mica monsters that did show value changes.
__________________
First comes the hardware, then the software.
  #3
Old 04-08-2010, 05:17 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Sometimes, capacitors fail without showing any external signs of distress.
Just the other day, I repaired one of our televisions that had a failed 220uF 200v electrolytic capacitor. One of the leads had separated internally from it's plate connection, resulting in an open circuit. The TV's picture had displayed obvious signs of a cap failure in the power supply (bad 60Hz "waves" on screen) before it's supply resistor burned up.
If your meter is the old fashioned D'arsonval type meter movement, you can discharge the capacitor with a low value resistor, then set your meter to read Ohms, and touch the test leads to the terminals. The meter needle will momentarily go towards nearly 0 Ohms, and then settle towards infinite.
A safer method is to discharge the capacitor, and then charge it via a resistor while measuring the voltage across the cap. You can then get an idea of the capacitance via the RC time constant.
See this chapter in our E-book: http://www.allaboutcircuits.com/vol_..._16/index.html
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #4
Old 04-08-2010, 06:57 PM
Member
Default
hey i'm a newbie and moreover i am a medical biotechnologist just started to leanr electronics. have some pity on me...
  #5
Old 04-08-2010, 07:10 PM
SgtWookie's Avatar
Expert Member
Default
Gee, I thought I was being helpful, and even gave you a reference where you can learn about RC time constants.
If you don't understand a portion of what was written, please quote the portion that you don't understand, and we will try to explain it so that it is more easily understood.
__________________
General info:
  #6
Old 04-08-2010, 07:13 PM
Member
Default
yes i will do all to be good at electronics.. thankyou
Tags
Related Site Pages
Section Title
Worksheet Switched capacitor circuitry
Worksheet Oscillator circuits
Worksheet Multi-stage transistor amplifiers
Worksheet BJT amplifier troubleshooting
Worksheet Class A BJT amplifiers
Worksheet Bipolar junction transistors as switches
Worksheet Capacitors
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Textbook 555 ramp generator : Analog Integrated Circuits
Textbook Input and output coupling : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need help finding replacement transistors CoolbeaN The Projects Forum 20 08-15-2012 07:33 PM
Quality Capacitors cldudley General Electronics Chat 10 01-12-2010 02:30 PM
BJT's - NPN Power Transistors Carel General Electronics Chat 12 06-21-2009 04:45 PM
Common transistors and capacitors for lab mrmeval General Electronics Chat 5 10-06-2007 04:30 PM
amplifier output transistors sampinoy General Electronics Chat 2 10-08-2004 07:08 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
