So basically I created this: THIS
The regular swich one ( second set of drawings )
My version has the switch very far away ( about 20m ) and the lamp with the battery and the transistor are closeby to eachother. I thought to use this transistor thingie version as I figured I wouldn't lose any amps (or whatevers) but when the button is pressed, the lamp is only faintly lit, as if the transistor didn't do any difference whatsoever... anyway... help... or show me a circuit that would work for me; a lamp that lights when I press a button about 20m away..
Thank you.
Thank you.
