All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-06-2010, 07:37 AM
justin77 justin77 is offline
Junior Member
Default Connect two transformers parallel
Can i connect two transformers after the AC to DC conversion in parallel as shown in the diagram.
  #2
Old 04-06-2010, 08:36 AM
t_n_k t_n_k is offline
Default
You can - in this situation the highest output at any instant will conduct into the parallel load path - by virtue of the diodes D1 & D2.
  #3
Old 04-06-2010, 09:12 AM
Junior Member
Default
Will the load get balanced. Will i be able to get more Amps from the combined circuit?
  #4
Old 04-06-2010, 10:01 AM
Default
You could probably lose the diodes (D1 & D2). The bridge rectifiers will themselves prevent backflow of current.
Perhaps you could explain why you want to take this approach - is it for a real circuit?
  #5
Old 04-06-2010, 03:14 PM
Junior Member
Default
Yeah this is. I need it to give power to my amplifier. One transformer is not enough as its maximum current is 2A. I need to have some method to provide 4A of current. So i was thinking of buying another 24 0 -24 V transfornmer and connet it in parallel.
  #6
Old 04-06-2010, 03:29 PM
nomurphy's Avatar
nomurphy nomurphy is offline
Default
Instead of building two seperate circuits, literally place the two equally rated xfmr's in parallel to double the output current capacity. Verify the diode bridge can handle the extra current, or upgrade it.
  #7
Old 04-06-2010, 03:40 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Make certain that you have the transformers connect in phase with each other.
If you have them out of phase, you will get 0v out and a pair of smoking transformers.
Connect the primaries to a fused and switched supply of mains power. Connect one of the ends of the secondaries together. Use a meter set to AC to test the voltage between the disconnected ends of the secondaries. If you have them in phase, you should measure very little voltage between the two. If they are out of phase, you will measure around 48vac.
If they are out of phase, you can swap either the primary or secondary connections.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
The Following User Says Thank You to SgtWookie For This Useful Post:
PaulC (11-12-2012)
  #8
Old 04-06-2010, 03:54 PM
Junior Member
Default
Quote:
Do you mean to connect the AC output's of the two tranformers in parallel?
Isn't it a risky thing to do. Isn't connecting DC outputs in parallel safer?
  #9
Old 04-07-2010, 12:38 AM
Bychon Bychon is offline
Default
If the 2 transformers are same brand, same number, they will be perfectly happy in parallel. If they are a bit different, the use of 2 rectifier circuits (like the drawing shows) will keep them from fighting each other.
In the real world, I have connected transformers of different brands, but both labeled 24 VAC, and they do not fight each other, so a little bit of difference doesn't seem to hurt.
  #10
Old 04-07-2010, 02:32 AM
Junior Member
Default
what if one DC output is 33.3V and the other is 35V only the 35V output generating transformer will be active.
Now if i draw 2A , 35V will drop to say 30V then the 33V transformer will become active. So only one transformer is ideally active at any one instance?
Am i corect?
Tags
Related Site Pages
Section Title
Worksheet Design Project: Dual-output AC-DC power supply
Worksheet Design Project: AC-DC power supply
Worksheet Design Project: Sensitive audio detector
Worksheet Impedance matching with transformers
Worksheet Series-parallel combination AC circuits
Textbook Single-phase power systems : Polyphase Ac Circuits
Textbook Special transformers and applications : Transformers
Textbook Sensitive audio detector : Ac Circuits
Textbook Transformer -- power supply : Ac Circuits
Textbook Sensitive voltage detector : Dc Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Parallel connect 2 camcorder batteries...possible ? marcolisi The Projects Forum 6 03-14-2010 03:28 AM
Connect two transformers in series jake77 General Electronics Chat 4 03-02-2010 10:40 AM
Keyboard matrix decoder B R The Projects Forum 1 03-06-2009 01:02 AM
parallel resistance and transformers wes General Electronics Chat 4 04-18-2008 06:41 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
