Could you explain please?VE remains constant and relative to VB. VRe changes with IC
Jony130, do you remember (can you provide a link) to an earlier post about biasing where you provided the expression for the case where part of the emitter resistance is bypassed with a capacitor?You get max output voltage swing if you pick Ic equal
\(Ic_{opt}=\frac{Vcc-Vce(sat)}{2(Rc+Re)}\)
what gives Vce≈0.5*Vcc
Yes,Jony130, do you remember (can you provide a link) to an earlier post about biasing where you provided the expression for the case where part of the emitter resistance is bypassed with a capacitor?
Hi guys,
Thanks a lot, i got it now.
Is it correct to say that:
VOUT(min) = VEE + IC*RE + VCE(SAT)
VOUT(max) = VCC
So to get maximal output voltage swing, i'd want to set VOUT at half way between VOUT(min) and VOUT(max).
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Jake Hertz
