All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-02-2010, 02:41 PM
arry arry is offline
Junior Member
Default voltage follower with an op amp
Hi all and thanks in advance for your help.
I am using an op amp MCP607 connected as a voltage follower (with negative feedback). Vdd is 5.0V and Vss is connected to ground.
When I pass 1V to (+)input I get 1V on the output, which is normal.
But If i pass 3.5V to (+)input I get 3.53V on the output, - well probably ok,
and if I pass 4.5V to (+)input I get 5V on the output. This is very strange to me.
This opamp has a 120dB Open loop gain and a 250uV input offset voltage.
Having read the article on op amps , I would expect to have a slightly lower voltage, say with a couple of mV, but not 0.5V.
What could be wrong?
  #2
Old 04-02-2010, 03:17 PM
Jony130 Jony130 is offline
Default
Well the max input voltage is equal Vdd-1.1V = 3.9V.
Read datasheet "Common mode input voltage"
http://ww1.microchip.com/downloads/e...doc/11177d.pdf
The Following User Says Thank You to Jony130 For This Useful Post:
arry (04-03-2010)
  #3
Old 04-02-2010, 04:37 PM
Junior Member
Default
so up to 3.9V the input voltage should be followed exactly, right ?
Then why 3.5V is followed as 3.53V ?
  #4
Old 04-02-2010, 04:48 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Do you have any load on the output of the opamp besides the noninverting input connection?
Do you have a 0.1uF bypass cap from the Vdd terminal to GND?
With no load and a bypass cap wired as a voltage follower, your output voltage should be within 250uV of the input voltage - as long as you're within the specified common mode voltage range.
If not, your opamp may have been damaged or may be defective.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
The Following User Says Thank You to SgtWookie For This Useful Post:
arry (04-03-2010)
  #5
Old 04-03-2010, 03:32 PM
Junior Member
Default
thanks , you turned out to be right my op amp was out of its common mode.
What op amp would you recommend for a good voltage follower to drive
ADC measurements ?
  #6
Old 04-03-2010, 04:56 PM
SgtWookie's Avatar
Expert Member
Default
Something like an LT6003 would be good.
Basically, you're looking for rail-to-rail inputs and outputs, low offset, and low drift that is stable at unity gain.
__________________
General info:
  #7
Old 04-03-2010, 06:23 PM
kkazem kkazem is offline
Default Single Supply Unity Gain Follwer
I agree. TI has a number of very good CMOS single-supply, rail-to-rail op-amps with a higher common-mode range than 3.9V on a 5V supply. Try looking at the TLV341 (click the attached link for the datasheet)http://focus.ti.com/lit/ds/symlink/tlv341.pdf . It has common-mode range up to 0.5V less than the supply, and rail-to-rail outputs. But here is what I really want to say: analog layout is critical, even in a run-of-the-mill unity-gain follower circuit. Here are a few things you must do to ensure trouble-free operation:a) Don't layout the circuit on a press-in type prototyping board. These are fine for low frequency digital and discrete low-gain analog, but bad for most analog, especially high-gain op-amps. b) Do layout on a vectorboard with pre-drilled holes and a copper, circuit board type prototype pattern. C) Do bypass the op-amp IC directly across the supply pins as close to the pins as you can get with a 0.1 uF and perhaps a 0.01uF in parallel with that. When I say direct to the pins, I mean it literally. The best way is to cut the cap leads very short and solder them on the bottom-side of the proto Vectorboard right on the supply and ground pins themselves. D) Do ensure you have a fairly clean power supply. If the vercotboard is more than 4-6 inches away from your power supply circuit (not including the power supply cable and/or connector), add a 10uF to 100uF across the power supply input on the Vectorboard. E) Place the feedback connection from the op-amp output to minus input very close to those pins and keep the wiring short. If using feedback resistors from the output to negative input, place the resistor with as short a lead as possible to the minus input side, and the other end going to the amp output can be longer and is far less sensitive to noise and external pickup. F) closely read the datasheet and especially it's applications section for any special requirements, like adding an output cap to the amp circuit to keep the circuit stable at unity gain. Make sure sure are within all the recommended limits of the IC (do not use the Absolute Maximum Ratings, as these are generally for transient conditions and not for continuous use, or be prepared for unexplained failures). It's a good idea to use a series resistor on the non-inverting (PLUS) input in your unity-gain follower. Not too high a value, perhaps 10K to 100K to protect the amp against input transient overvoltages. G) Although I don't know what your load on the amp is, make sure that the load is within the capabilities of the op-amp or else you may need a buffer amp to boost the output current with an NPN emitter follower or similar, although there is a price to pay with losing the rail-to-rail output on the positive side (you'll lose about 0.7V in the follower ckt). Make sure the op-amp slew rate is fast enough for the type of input you're using. If it's a slowly changing DC input, no need to worry about it, but if you're using fast square waves, you must worry about it. Make sure the amps GBW (gain-bandwidth product) is fast enough for the frequency of signals (or rep rate) of your input. H) Be careful of any unused inputs. If you're using a dual or quad op-amp and one side is unused, tie both unused inputs to ground. The TLV341A I recommended has a shutdown pin. Make sure to hardwire it to the proper point to disable that input so that noise doesn't falsely shut down your amp circuit. I hope this helps.
Good luck
Kamran Kazem
__________________
Kamran Kazem,
Senior Member of IEEE with 30+ years of power electronics, & general analog, digital, & microprosessor design. BSEE & MBA from UC, Irvine
kkazem
The Following User Says Thank You to kkazem For This Useful Post:
arry (04-14-2010)
  #8
Old 04-13-2010, 07:35 PM
Junior Member
Default
I will try to look for tlv342 but in the mean time I am playing with mcp6142 op amp.
Common mode from Vss-0.3V to Vdd+0.3V, input offset 10mV, rail-to-rail output.
So when my +input has 4.82V, on the output I get 4.92V. This is 100mV instead of 10mV. Is that normal?
The op amp is connected as a voltage follower,Vss to ground, Vdd=5V, no bypass cap, no load on the output pin.
  #9
Old 04-14-2010, 01:06 AM
retched's Avatar
retched retched is offline
Default
with a gain of 10 it would be
__________________
-rm-
  #10
Old 04-14-2010, 01:34 AM
SgtWookie's Avatar
Expert Member
Default
From Microchip's MCP6142 page (link: http://www.microchip.com/wwwproducts...cName=en010453 )
MCP6142 - 600 nA, Non-Unity Gain Rail-to-Rail Input/Output Op Amps (MCP6141/2/3/4) (5/14/2009)
The MCP6142 is a dual 600nA op amp offering rail to rail input & output over the 1.4 to 5.5V operating range. This amplifier has a typical GBWP of 100kHz with a maximum quiescent current of 1 microampere
Rail to Rail input/output swing G>10 stable
So, without even looking at the datasheet, you should have known that you would need a gain > 10 for it to be stable.
You cannot operate that opamp at unity gain.
The 10mV offset really is quite high.
It does not meet two important specifications that I gave you.
I would not have selected that opamp.
The devil's in the details.
[eta]
I'll add a couple more items to the list:
1) Don't use a micropower opamp for your buffer/voltage follower.
2) use an opamp that has at least 1MHz bandwidth.
You want the opamp to bring the ADC input very rapidly to the voltage that is at the noninverting input of the opamp, and be able to hold that voltage steady while the ADC is sampling it, which means a low impedance output from the opamp.
A 10nF cap at the ADC input will help to keep the voltage stable while it is performing it's sampling, but you need an opamp that can respond rapidly enough, and supply enough current to keep that cap charged to the proper level.
If you have to drop one of my suggested specifications, then ditch the "low offset" specification, as you can compensate for the offset by subtraction in your ADC sampling routine.
__________________
General info:
arry (04-14-2010)
Tags
Related Site Pages
Section Title
Worksheet Performance-based assessments for analog integrated circuit competencies
Worksheet Inverting and noninverting opamp voltage amplifier circuits
Worksheet Negative feedback opamp circuits
Worksheet Basic operational amplifiers
Textbook Practical considerations : Operational Amplifiers
Textbook Negative feedback : Operational Amplifiers
Video Lecture Basic Amplifier Configuration (Part 1) - Op Amps and Op Amp Circuits
Video Lecture Op Amps Characteristics (Part 4) - Common vs. Differential - Op Amps and Op Amp Circuits
Video Lecture Op Amps Characteristics (part 1) - Op Amps and Op Amp Circuits
Textbook Precision voltage follower : Analog Integrated Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Why/how do capacitors resist change in voltage? shespuzzling General Electronics Chat 18 08-29-2009 08:37 PM
difference between circuit with op amp voltage follower, and one w/o dacrazyazn Homework Help 6 04-08-2009 05:11 PM
How to measure offset voltage and polarization currents of an op amp? msr Homework Help 3 03-24-2009 01:06 AM
Op Amp Feedback Biasing Voltage alt234 General Electronics Chat 6 03-15-2009 05:47 AM
Treatise about Voltage Ratch Physics 100 05-18-2008 07:55 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
