All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-31-2010, 03:48 PM
vinodquilon's Avatar
vinodquilon vinodquilon is offline
Smile Home automation using phone (dtmf touch-tone)
Here I am presenting my final mini-project setup.
See the attachment in this forum or the link...
http://www.***********/doc/29233455
I express my sincere thanks to all forum members for there great support
without whom this project wouldn't have been a reality.
Still I am welcoming new ideas to improve my final circuit.
  #2
Old 03-31-2010, 04:26 PM
Default
7805 labels are reversed, I will clear it.
at board 3 there should be 4.7K replaced with 470 Ohm and a 1K preceding all LED s.
  #3
Old 04-02-2010, 02:18 AM
Thumbs up Here is the modified one...
http://www.***********/doc/29306350
  #4
Old 06-13-2010, 02:10 PM
Smile teleswitch_DTMF.Finally Revealed...
Take a look at my attachment.
  #5
Old 06-13-2010, 02:23 PM
retched's Avatar
retched retched is offline
Default
I'll look at yours, if you look at mine.
You have a very interesting way of routing traces. It looks like something out of Mad Max.
Can you plug this into a standard modem to receive the DTMF tones? That would make PC based software pretty easy. You could send standard 'AT' commands to the modem to control the units.
__________________
-rm-
  #6
Old 06-13-2010, 02:43 PM
Thumbs up
First time I heard about AT commands.
The goggled search result is
http://www.activexperts.com/xmstoolkit/atcommands/dtmf/
Now I will try that possibility.
Thanks...
  #7
Old 06-13-2010, 03:02 PM
retched's Avatar
Default
Yes, it can make your life easier.
To send "4105551234" to your device, just plug the device into the modems phone jack and send
ATD4105551234 to the com port that the modem is on.
Also, If you needed to press 1 to select a device then 2 to turn it on, you can use 'P' or a comma to send pauses in the dialing command.
For instance, if '1' selects the livingroom light, then '1' again turns it on or '2' turns it off:
ATD 1,2
Will send the DTMF code for '1' selecting the light then the comma will pause for a second then send the '2' to turn the light off.
And it is quite simple. There are also codes for length of time the tone is sent and the amount of time of tones.
For instance, ATS11=50 sets the register for the amount of time of tones to 50ms. If your device needs more time to recognize tones, you simply send the ATS11 command with the number in milliseconds that you need the tones.
Here is a list of the AT commands:
http://pcmicro.com/support/modem_at_commands.html
And here is a list of the registers. See S11 like ATS11 is the register for DTMF tone duration
http://pcmicro.com/support/modem_s_registers.html
__________________
-rm-
The Following User Says Thank You to retched For This Useful Post:
vinodquilon (06-13-2010)
  #8
Old 09-16-2010, 04:19 PM
Smile Report attached
Report attached....
__________________
@VQ
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
