All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-30-2010, 10:52 PM
7yler 7yler is offline
Default DC motor as generator.
I am attempting to build a wind turbine, as many have successfully. I have read that a permanent magnet dc motor out of a treadmill will serve well as the generator for the turbine. I'm not very electrically savvy, but I'm attempting to learn. I have posted pictures of the motor, and the multimeter that I'm using. I hooked up the red wire on the motor to the red wire on my meter, and the black wire on the motor to the black wire on my meter. I then chucked the spindle of the motor and spun it in my drill to see if I could get a reading on the meter. I had no reading on any of the "DC V" settings, and no reading on any of the "AC V" settings. BUT, I did have a reading of around 10 on the "12A" setting. I tested all settings turning the motor clockwise, and well as ccw. What does this mean? Am I able to use this as a generator for a wind turbine? Thanks for any help.
  #2
Old 03-31-2010, 01:20 AM
hazim hazim is offline
Default
The motor is rated 7099rpm and 130VDC. 7099rpm is very high for the motor to use it for a wind turbine, except if you will use a gear box or other mechanical way to increase the speed but this isn't good for stability. This motor won't generate even 0.5VDV at low rotation speed like the way you rotated it.
The rated speed should be about 3000rpm at maximum, the lower the better. The wind will not rotate the turbine at this speed, at this speed the motor generate a voltage near the rated voltage like 130VDC. What happens is that the wind rotates it with a fraction of the rated rpms which generate a voltage around 12V DC, where this output voltage should be regulated and then 12V batteries (best choose are deep cycle batteries) could be connected to be charged.
I'm interested in building a small wind turbine, actually I want to build one, what w need is a treadmill motor (or similar) with low rated rpm (3000 maximum - it depends on the rated voltage too..)
I made a research about these small wind turbines that use permanent magnet motors.
See this web page it's interesting and very beneficial for who wants to build a wind turbine: http://www.mdpub.com/Wind_Turbine/index.html
  #3
Old 03-31-2010, 01:48 AM
BMorse's Avatar
BMorse BMorse is offline
Default
3000 rpm's is still way to fast to generate any usable power from it in a windmill.... you need a Permanent magnet DC motor that has VERY low RPM's (100 to 350) and very high voltage (90 to 130 VDC or higher preferably).....
see my Windmill project work log, here >> http://www.morse-code.com/windmill_generator.htm
B. Morse
__________________
There is no spoon -Neo-
Disclaimer: The example programs,circuits, projects and information I provide or post on this web site are for educational purposes only. By copying anything from this site posted by me, you agree to the "as is" nature of the programs, circuits, information and to the statements listed in this disclaimer.No warranty or liability is expressed or implied. Working with AC /DC voltages can be dangerous and even deadly. Proceed at your own risk!
  #4
Old 03-31-2010, 08:00 AM
Default
Quote:
BMorse is right, but don't you think a 250VDC 2500rmp permanent magnet DC motor is still good? I think yes.
A 350rmp 30VDC PMM is a good choice.
350rmp/30V = 11.7
3000rmp/250V = 12
This is why I see it good.. Yes the rpm's are high but also the rated voltage is high as I said.
Tags
Related Site Pages
Section Title
Worksheet AC motor theory
Textbook AC commutator motors : Ac Motors
Worksheet AC generator theory
Textbook Tesla polyphase induction motors : Ac Motors
Textbook Brushless DC motor : Ac Motors
Textbook Stepper motors : Ac Motors
Textbook Synchronous Motors : Ac Motors
Worksheet Design Project: DC motor
Worksheet DC motor theory
Worksheet DC generator theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
Isolated DC pulse generator help needed. alan-1981 The Projects Forum 0 02-16-2010 08:14 PM
Is there 1 volts dc relay mrel General Electronics Chat 1 12-16-2009 11:19 AM
smoothing dc transformer ? Mathematics! General Electronics Chat 23 11-23-2009 10:12 PM
Generator AC to DC Macgyverasb The Projects Forum 10 11-16-2009 03:17 PM
DC GENERATOR EXITER (important) papmalik The Projects Forum 2 10-22-2009 04:08 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
