I don't have much experience with electronics but I make simple projects here and there when I need to. My current project is a timing light that I want to house in a plastic pencil case. The pencil case is absolutely perfect, except that the plastic it's made from collects static.
I've heard that IC's can be wrecked by static and want to protect them in some way. My instinct is to just wrap my circuit in aluminum foil, with maybe some cardboard or electrical tape preventing any shorts. Researching online all I can find is that static is scary, but no one says what to do about it.
Please share your wisdom. Is this a valid concern? Will it work? How much aluminum foil should i use?
Also, how would I know if static has affected my components, do they just die?
