All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-28-2010, 05:42 PM
jaangalab jaangalab is offline
Junior Member
Default 1khz 100v 500w power supply
hi frnds i want to make a power supply 1khz 100v 500w pls sugest me circuit ihave a circuit but it igbt due to cost i want to mate it from transiter if any body have circuit pls share me
thanks
  #2
Old 03-28-2010, 06:18 PM
beenthere's Avatar
beenthere beenthere is offline
Default
Could you give some more information? Most power supplies are for DC power. The 1 KHz requirement is hard to understand. What is this power for?
__________________
First comes the hardware, then the software.
  #3
Old 03-28-2010, 06:24 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Along with the information Beenthere asked for, what kind of input power do you plan to use?
Mains power at 120v/60Hz, 220V/50Hz, battery power?
If battery power, what battery type, output voltage and AH rating?
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #4
Old 03-28-2010, 08:33 PM
rogs rogs is offline
Default
I use what you describe all the time in my work, but I don't call it a power supply - I call it a 100 volt line audio power amplifier!
100 volt line is the common output for distributed public address systems, here in the UK. (I believe the US uses 70 volts).
Use a class 'D' audio amplifier, and a linear toroidal transformer, and you should get something like 85- 90% efficiency.
  #5
Old 03-29-2010, 02:37 AM
Junior Member
Default
the circuit i want is used for strips mill my input is 415v 50hz i need constant current 100v 1khz 500w output is conect to a coil winding on a soft iron plate
  #6
Old 03-29-2010, 09:51 AM
JDT JDT is offline
Default
I assume this is for inductive heating? If it was resistive heating then the frequency would be unimportant.
I think the cheapest way will be to get a large audio amplifier. I have some that are 2 channel at 500W per channel (but you are not having them!) These are rack mounted "2U".These can be "bridge connected" with a switch on the back making them single 1000W. You would get more than 100V without a transformer.
Build a simple 1KHz sine wave oscillator. Feed this into the input. Monitor the current with a DVM on AC current range in series with the load. Increase gain SLOWLY from zero and see what happens!
Try ebay for the amplifier. Disco and professional audio section. Expect to pay £150 plus. Better quality amplifiers have better overload protection. Not worth building one.
  #7
Old 03-29-2010, 04:14 PM
Junior Member
Default
sorry i want make not buy if u have circuit pls share me it is not for induction heating
  #8
Old 03-30-2010, 08:01 AM
Default
If cost is an issue, then as both JDT and I have suggested, a high power audio amplifier would probably be your best option. You are unlikely to be able to build one for less than you can buy one, but if you feel you can, just Google audio amplifier schematics -there are lots of them out there!
  #9
Old 03-30-2010, 09:37 AM
Junior Member
Default
i get a 800w audio amp schematics from google can it solve my tention and i have to attach it 1khz how can i make it and how can i make feedbake cirent limit voltage limit in it pls sugest me
thanks
  #10
Old 03-30-2010, 12:35 PM
Default
That circuit appears to be based on the original Hitachi circuit from the 1980's that was published as an application for their lateral mosfet output devices. It should work OK, but there are one or two points you need to be aware of:
1) You're going to need a fairly massive heatsink to be able to dissapate the heat generated by a class A-B audio amplifier, providing a continuous 500W output. You'll probably need to dissapate in the order of 400 to 500W of heat, on a continuous basis.
I would guess that will require a forced cooling (fan) arrangement of some sort.
2) Class A-B amplifiers are not efficient - typically 35-55%, depending on load conditions, so you are going to have to generate at least 1000W of DC power at +/-85V to supply an amplifier based on the circuit published.
This is going to cost you a lot more money, for a one off project, than simply buying a commercial class D amplifier of the required rating. Are you sure you really need to build your own, if it's more expensive?
The Following User Says Thank You to rogs For This Useful Post:
jaangalab (03-31-2010)
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Submission: Power Supply Circuits Bill_Marsden Feedback and Suggestions 50 07-30-2012 10:50 PM
Switching Power Supply Construction Tips radiohead General Electronics Chat 4 06-05-2009 01:22 PM
7805 & 12VDC Power Supply Problem JDC The Projects Forum 10 10-24-2008 06:09 AM
Power problem...but not the power supply. BiggerBean Computing and Networks 15 05-22-2008 10:35 PM
Help with power supply Toby Craig The Projects Forum 4 11-25-2007 10:31 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
