All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Embedded Systems and Microcontrollers
Notices
Embedded Systems and Microcontrollers Discussion forum for projects and working with embedded systems and microcontrollers (FPGAs, PICs, AVRs). Get help with hardware issues and embedded programming.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-22-2010, 07:52 AM
seeyou seeyou is offline
Default RFID Ethernet micro framework
I like to make my first start with I Microcontrolling. I like to make a application that allows clients to registrant there ID by RFID. The box will connect to Ethernet to computer and a written application C# application on a computer.
Can somebody help me with this? Is there board good to connect RFID, supports MS micro framework and Ethernet and is not so expensive.
ehm... I am not really good with soldering so everything by cable would by nice
Thank you so much
Wouter
  #2
Old 03-22-2010, 08:40 AM
rjenkins rjenkins is offline
Default
It sounds like you need to make it a PC based unit to be able to use standard parts.
Have a look at ITX and XTX/ETX standard motherboards. These are small, low power types ideal for building in to other gear.
ITX is 170mm square (about 7") and XTX/ETX are 95 x 114mm (about 4 x 5")
Examples:
http://www.kustompcs.co.uk/acatalog/...ds_ITX_83.html
http://www.avalue.com.tw/products/XTX-US15WP.cfm
Many places that sell these also sell parts like 12V input power supplies to suit the boards.
You could make the whole thing boot & run from a USB drive.
__________________
Robert Jenkins.
  #3
Old 03-22-2010, 01:00 PM
Default
Thank you Robert Jenkins.
I like to use a microcontroller or dev-board . I like to have them as kind of experence.
Thanks,
Wouter
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
RFID Remote Start/Alarm Schematic help XtremeBoomer2007 The Projects Forum 8 04-15-2009 05:42 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
