All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Embedded Systems and Microcontrollers
Notices
Embedded Systems and Microcontrollers Discussion forum for projects and working with embedded systems and microcontrollers (FPGAs, PICs, AVRs). Get help with hardware issues and embedded programming.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-21-2010, 05:18 AM
Acrobat Acrobat is offline
Default Usefull combination: AT90USB646 + AVR Dragon?
I am very new to microprocessors, but I want to construct a device, that needs to have some small display and some buttons. Most times it is connected to a PC (USB preferably), but it needs also some limited logic on its own, for the times, it is not connected.
After some web search, I came up with the above mentioned combination of microprocessor and development board. According to the Atmel list of supported devices the AT90USB646 is supported by the Dragon. What I am unsure is:
a) according to the product specification page at the shop, the AT90USB646 is a SMD device. Can I really put that onto the Dragon for programming it? Or do I first have it wired on another board (breadboards, you're calling them, right?) and wired it with dozens of connections to create a ISP or JTAG port, before I can program it?
b) How hard is it, to program the USB interface to act like a USB-Serial device (so, that it looks like a COM port on the PC)?
c) do I need anything else to get started with this chip?
thanks a lot for you help. This whole stuff is quite hard, if you're just starting.
  #2
Old 03-22-2010, 04:07 PM
Rush Rush is offline
Default
First of all you need a board with AT90USB646 on it or something like adapter to connect MCU to breadboard, because selected MCU is SMD. I'm not sure in the difficulty of programming, but for your task I'd rather use FTDI chips (or their analogs).
For the c) - this depends on your final task.
Also I would suggest to trying with demo-boards like Atmel Butterfly. After some experiments you can add FTDI chip and use Butterfly for your initial task.
With kind regards, Kirill.
  #3
Old 03-22-2010, 05:13 PM
Markd77's Avatar
Markd77 Markd77 is offline
Default
You might not even need the dragon. From a quick look at the datasheet it has a bootloader so you should be able to hook it straight up to the USB port to program it. I've got no experience with this but it might be worth looking into.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
PIC vs. AVR - MIPS Vaughanabe13 Embedded Systems and Microcontrollers 21 07-12-2009 11:39 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
