All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #11
Old 04-12-2010, 10:35 PM
kd7ura kd7ura is offline
Junior Member
Default similar situation need auto start circuit
ive got a gen with the auto start built in , im looking at a low voltage detector and voltage monitor circuit with leds, trying to figure out how too put them together with a relay to trigger the auto start on the gen.
i need the relay to close to get gen to auto start when the battery bank reaches low voltage point of 11.89 VDC stay closed untill battery bank reaches full charge of 13.8 vdc then open relay to shut down gen.
i have two wires coming from the gen by putting them together it starts,runs and shuts down when you seperate them. i believe they draw 12volts from the generator battery to trigger the auto start feature.
the gen will run 220 v to two xantrex inverters , one on each leg and they will invert and charge the batteries,
ive looked at the mc34161 detector chip for voltage checking and LM3914 for the led display monitor i need a recomandation for a relay to trigger the gen and how i would put them together.
The Following User Says Thank You to kd7ura For This Useful Post:
pursefocus (06-11-2010)
  #12
Old 04-12-2010, 10:52 PM
R!f@@'s Avatar
R!f@@ R!f@@ is offline
Send a message via MSN to R!f@@
Default
kd7ura
hijacking is bad.... dude.
Start a new thread for your problem
__________________
R!f@@
Do not get angry and do not be harsh because you will never regret being kind
  #13
Old 04-13-2010, 12:06 AM
aq_rules aq_rules is offline
Default
@ shaz
Where u from?
  #14
Old 04-13-2010, 12:10 AM
Default
it is not possible my boy without an ATS system...which is much expensive...and if u're thinking of making an Automatic Transfer Switch yourself tht would cost u more than the readymade...
  #15
Old 04-28-2010, 01:21 AM
songdinhvu songdinhvu is offline
Default
hi
i have a board auto start and stop generaror now i i am drawing it to schematic diagram when it finish i up load.
  #16
Old 04-28-2010, 12:00 PM
retched's Avatar
retched retched is offline
Default
Thank you. You should post a new thread in the Projects form so others can find it easily.
__________________
-rm-
  #17
Old 06-08-2010, 02:28 PM
zia79 zia79 is offline
Default
try this circuit not perfect but good, im working on this as i complete i'll post schematic .low voltage sensing circuit is missing in this circuit, and ats system is a little bit tensing, but starting circuit is cool.
  #18
Old 06-11-2010, 06:24 AM
Default
Quote:
Originally Posted by eblc1388 View Post
Expensive ATS does this transfer step without power interruption. That's why it is so expensive in the first place.
An ATS is definitely not a project for hobbyist.
i am sorry to say u are wrong, a 60 amp ATS system home built costs no more than 12$ WITH TIME DELAY SYSTEM.
  #19
Old 06-11-2010, 11:38 AM
retched's Avatar
Default
Woah. Alright mister $12. Ill finance it. Where is the schematic and parts list?
__________________
-rm-
  #20
Old 06-11-2010, 02:33 PM
ismailgunyuzlu ismailgunyuzlu is offline
Default
How I knowing adjustibilty speed of governors on 150mW steam turbine? can you help me about This varies with different classes of insulating materials, Speed regulator speed drop and Speed regulator gain on steam turbine?
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
auto switching relay for 2 strings of batteries Thumpalong The Projects Forum 0 01-13-2010 02:42 AM
desiel generator auto start ibegbu_e General Electronics Chat 1 11-19-2009 05:18 PM
Help With Circuit,, Auto Dimmer, cant find one jgraham83 The Projects Forum 3 05-14-2009 11:02 AM
Auto Run CD MVIBoss Computing and Networks 4 01-28-2007 12:58 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
